Old 01-22-2012, 02:00 AM   #1 (permalink)
Buggie - '01 Vw Beetle TDI Gls
Cheap high test gas
Been pondering this a while since I saw a chart with different fuels compared, energy and octane rating. Jet fuel, kerosene and diesel are not too different, while regular , mid and high test are lower octane fuels
Tonight I dumped 2 gallons of diesel in with a full rank of regular to see how the truck will respond. It calls for premium, I'll have to find the chart again to figure out how much to mix next time.
Old 01-22-2012, 03:11 AM   #2 (permalink)
Ladogaboy - '11 Mitsubishi Lancer EVO GSR
Team Emperor
90 day: 27.64 mpg (US)
E85 EVO - '11 Mitsubishi Lancer EVO GSR
90 day: 21.38 mpg (US)
Ummm... I'm no expert, but I'm not sure if that is advisable. That might throw the timing of your vehicle off and cause quite a bit of knock. From my personal experience, we used to mix diesel and gas to make burn-can fluid. Too much gas, and the mixture would explode. Too much diesel, and the mixture would drown and put out the wick.
Old 01-22-2012, 11:29 AM   #3 (permalink)
A bit of diesel would increase the octane rating which would reduce knock.
Old 01-22-2012, 11:32 AM   #4 (permalink)
Just checked the msds for octane booster. It is (60-)99% kerosene and up to 5%other ingredients. Basically Diesel fuel
http://www.amsoil.com/msds/aob_cob.pdf
Old 01-22-2012, 11:53 AM   #5 (permalink)
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Diesel does not contain octane. It contains Cetane.
Octane = resistance to auto-ignite. The more there is the less likely to auto-ignite. Spark ignition engines need this so that only the spark plug lights the fire.
Cetane = ability to auto-ignite. The more there is the more likely to auto-ignite. Diesel engines need this because they rely on heat from compression (only 600F) to light the fire.
When I was a kid I put some diesel fuel into my dad's car. It wasn't much, but it WAS enough to make is run like crap...AND enough to get a beating.
Old 03-06-2012, 10:32 PM   #6 (permalink)
So I had three fill ups since I started this and notices a significant fuel economy increase. The timing is set to stock- for premium- and I have always used regular. With straight regular I have been getting 10.5 mpg mixed, my last fill up was just over 13mpg, with suggested amounts diesel added (as on octane booster bottle, 2 gallon was way too much)
So overall, I'm going to get a exact measuring device (old octane boost container)and carry some diesel with me in case I need to fill up alon the way. Tonight regular was 1.26/l and premium was 1.41/L. At a savings of 15cent per little, 80 liters I saved $12 in fuel, and with the increased mileage it's even more (still crap)
Old 03-07-2012, 05:28 AM   #7 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 144.39 mpg (US)
Send a message via MSN to jakobnev
Are temperatures up where you live?
Old 03-07-2012, 07:54 AM   #8 (permalink)
Been mostly 5-10 below freezing
Old 03-07-2012, 08:56 AM   #9 (permalink)
Heed the warnings about pouring diesel in a gas tank or vice versa. Mercedes recommended adding gasoline to diesel fuel for extreme cold temp operation, but there was a big highlighted warning about pouring one into the other. I think it was diesel in a gas tank but this is ancient memory (1982). The were very adamant about the danger., and I think it is what you are doing (diesel in a gas tank).
regards
Mech
Old 03-07-2012, 09:55 AM   #10 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 26.69 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
I have used and still use diesel in my gas. I have noticed better power and mileage. I use about 10% diesel. I have not had any problems.
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
The Following User Says Thank You to IsaacCarlson For This Useful Post:
bandit86 (03-07-2012)
