rusEfi: DIY ECU
DIY as in real Do-It-Yourself from scratch.
I am Andrey, I am involved with www.rusefi.com - that's a project to develop an open-source DIY engine control unit. I hope that this might be relevant - if you have full control over ECU logic and firmware you can potentially implement all kind of fuel-saving features, starting from alternator charging control to maybe shutoff @ stoplight? Anyway, back to rusEfi. This is all still pretty alpha version, we only have two engines running this. We have our Frankenstein board we use for ECU hardware: http://rusefi.com/images/Frankenstei...0306_state.jpg And we have a wiki/forum website. Oh, and as I said - we have two engines running this, another one can join maybe later this week: https://www.youtube.com/watch?v=M-qqHQ-quFg https://www.youtube.com/watch?v=neGVmxol0Gc So if anyone would be interested I would love to help with setting you up for rusEfi DIY ECU :) Another thing - there is a KickStarter project behind this: https://www.kickstarter.com/projects/312898525/rusefi-gpl-automotive-engine-control-unit-ecu-firm |
Would it also work with Diesel engines? A fully stand-alone ECU would caught the attention of the folks willing to use some of the newer-generation Diesels for swaps instead of the good old Cummins 4BT...
While gasoline and diesel have a 90% overlap, there is that 10% difference - so, rusEfi would support diesels only if someone would go and implement the missing functionality.
For 2014 focus is definitely on older gasoline engines: I know that GDI is too advanced for us, same issue with CDI. |
Just wondering if you were aware of the megasquirt (open source also). This sort of thing was kickstarted a long time ago.
AFAIK it was never "free open source" - older versions were "you can see the code but you have to use authentic hardware" and current version is plain closed sourced. That's why I believe there is space for a GPL open-source firmware. |
None of these commercially-available stand-alone ECM setups are open-source.
Saw your project featured on Hackaday... very cool to see you join here too! Would also enjoy seeing a diesel engine implementation
MS-2: 24 MHz, 4 kB rusEfi: 168MHz, 192kB While you can run an engine even on 8MHz, the extra speed and RAM makes the source code much easier to modify & extend, it's just a different level of comfort for software developers. |
Copyright ©2000 - 2022, vBulletin Solutions Inc.
