Rust
1 Attachment(s)
One sauce to rule them all?
https://ecomodder.com/forum/attachme...1&d=1677792975 I knew ATF was probably better than wd40 or pb blaster but I had to be able to drip some ATF on the offending parts and let it sit for at least overnight or apply heat with a torch. When torching or inductively heating wd40 and pb blaster burn off almost instantly, ATF hangs around for a bit before burning off. The advantage of pb blaster or wd40 is it has a red straw sprayer that gets it into places where ATF cant. For the last decade or so I mostly use wd40 as cleaner and pb blaster for rusty stuff. I guess cutting atf with solvent makes it work faster? By the looks of it I should just dump my pb blaster in the nearest Ohio river and get liquid wrench or that other one I never heard of. Surprisingly this isn't a post trashing Alec Baldwin for shooting that lady who was by total coincidence was filming a documentary on child trafficking. But it can be. |
I had missed the WD-40 in a squirt can when they went to the straw tapped to the side because they never had enough propellant. |
Assortment of comments: pb blaster is rumored to be a mix of dextron ATF and mineral solvents
A rubber gasket style washer added to a tire chuck with the center pin removed makes a dandy aerosol can re pressure device. Pressure in the chuck opens the valve in the can. |
The green paint all over the shed wall says yes. :)
I meant trying to open when there was (absolutely) not enough propellant.
