Old 03-02-2023, 04:49 PM   #1 (permalink)
Rust
One sauce to rule them all?
I knew ATF was probably better than wd40 or pb blaster but I had to be able to drip some ATF on the offending parts and let it sit for at least overnight or apply heat with a torch. When torching or inductively heating wd40 and pb blaster burn off almost instantly, ATF hangs around for a bit before burning off.
The advantage of pb blaster or wd40 is it has a red straw sprayer that gets it into places where ATF cant.
For the last decade or so I mostly use wd40 as cleaner and pb blaster for rusty stuff.
I guess cutting atf with solvent makes it work faster?
By the looks of it I should just dump my pb blaster in the nearest Ohio river and get liquid wrench or that other one I never heard of.
Surprisingly this isn't a post trashing Alec Baldwin for shooting that lady who was by total coincidence was filming a documentary on child trafficking. But it can be.
The Following 2 Users Say Thank You to oil pan 4 For This Useful Post:
Ecky (03-22-2023), ME_Andy (03-05-2023)
Old 03-02-2023, 05:56 PM   #2 (permalink)
But it can be.
I had to think for a minute to make the connection.
I had missed the WD-40 in a squirt can when they went to the straw tapped to the side because they never had enough propellant.
"If you don't read the newspaper, you are uninformed; if you do read the newspaper, you are misinformed. " someone who was not Mark Twain
Old 03-03-2023, 08:28 AM   #3 (permalink)
Joggernot's Avatar
Somewhere on youtube there is a guy who shows how to add 2 lbs of air to an airosol can to make it good as new. Only need an adapter and something that can do more than 2 lbs of pressure.
The Following User Says Thank You to Joggernot For This Useful Post:
freebeard (03-03-2023)
Old 03-03-2023, 09:44 AM   #4 (permalink)
Assortment of comments: pb blaster is rumored to be a mix of dextron ATF and mineral solvents
A rubber gasket style washer added to a tire chuck with the center pin removed makes a dandy aerosol can re pressure device. Pressure in the chuck opens the valve in the can.
The Following 2 Users Say Thank You to Piotrsko For This Useful Post:
freebeard (03-03-2023), Joggernot (03-04-2023)
Old 03-04-2023, 01:51 PM   #5 (permalink)
Have you never attempted to open an aerosol can?
Old 03-04-2023, 02:11 PM   #6 (permalink)
The green paint all over the shed wall says yes.
Old 03-04-2023, 11:16 PM   #7 (permalink)
I meant trying to open when there was (absolutely) not enough propellant.
lies, movie, rust, scam
