Sandy Munro compares Model S built quality to a 90s Kia
I think we have discussed Munro before, he tears down everything from small appliances to airplanes to tell competitors how stuff works. https://jalopnik.com/tesla-model-3-t...ual-1822678045
People in the comments said to cut them slack, they have been building cars for as long as Kia had in the 90s. If I am getting a mortgage for a car, I want perfection! I remember sharing an article about how difficult it was to open the trunk on a Prius when the battery died. Someone said they fixed that in later models. A comment on the Jalopnik page: Quote:
I'd call those design flaws (AKA bugs), rather than build quality issues. Same as my 1st-gen Insight, which doesn't run if the 12-volt battery is (nearly) dead, even though the traction battery is fully charged.
The traction battery needs a controller to be useful and that controller is powered by the 12V system.
I don't mind jumping an EV to get it working again. The charge port is useless if there is no 12V as the battery brain is needed to be able to charge anyway. The fools that dragged a BMW I3, wheels locked and all, onto a tow truck and toward a BWM dealership only to have the dealer jump it and drive it off by its own force should have RTFM tattooed somewhere though. |
Last I checked, no normal cars start with a dead 12V battery... Is this a design flaw too?
That is what you deserve for purchasing a car with an automatic.
Indeed, I probably started my old Austin-Healey that way almost as often as I used the started. Lucas electrics, you know? And yes, it is a design flaw because it would be simple to make the DC/DC converter provide current from the traction pack. |
My thought was a momentary switch that can be manually operated that closes the contactors. Hold the switch long enough to charge the 12v battery, a minute or 2, and then the 12v battery can take over holding the contactor closed. The power required to "start" an EV is very low compared to an ICE. A very small 12v source is all that is needed to provide just enough to run the computer and close the contactor, then the traction battery takes over. |
Small, super-powerful, 12Vdc Li-ion battery inside a simple, old-fashioned, IGNITION KEY; just plug it IN to "start" the 12Vdc electronics.
Ecomodders invented the MPGuino and the cool kids are installing them into their cars. T_vago has this interesting project: http://ecomodder.com/forum/showthrea...ead-26469.html. Daox makes shifter knobs that go "Pew pew" and "Vroombwahaha." We have fan indicator lights. People have put engines into cars despite absolutely not belonging and other nightmares of wiring, but nobody has figured out how to make it easy to recover a dead electric car?
I'd carry something like this, as it could come in handy for charging a phone or used as a flashlight: http://telwin.it/export/sites/defaul...1468683548.jpg |
https://i.ytimg.com/vi/PI46qVW2WA4/hqdefault.jpg
https://i.ytimg.com/vi/PI46qVW2WA4/hqdefault.jpg Why would anyone drive anything they can't start with the leather belt they are probably already wearing? :) I know, glow plug, right? |
It took me an hour to get a hold of the right mechanics, but one of those jump-started my bus with one of those small lithium jump-starters. I was amazed something so small brought something so large to life.
My Lieutenant still tried to get me in trouble for that I am pretty sure I did not understand why at the time. I have also been intrigued by the ones that plug into your 12v port, but that is another thing I need to fix on my Civic... :) |
There just isn't any point. Who is so lazy they refuse to pop the hood to connect a jump pack? Maybe if I was wheelchair-bound it would make sense, but normally-abled people have no reason to be lazy. |
The Telwin Mini has maximum starting amperage of 1,000: http://www.telwin.com/en/prodotti/?i...&idPrec=829392
Ten amps seems... less... Do you have to ruin everything?! :D |
Here's what I thought you were talking about: http://www.techgalerie.com/images/2006/2006_320.jpg https://www.vat19.com/item/auto-jump...without-cables Cigarette sockets are usually protected by a 10a fuse, so they can charge a jump pack slowly, but aren't very practical for going the other direction to jump the main vehicle battery. To fix your cigarette socket, check the fuse first. If that's good, check the wires at the back of the socket. They sometimes come loose. https://img.banggood.com/thumb/water...1321%20(3).jpg |
Somehow I was clearer the first time than the second. Yes, I referred to 12v car jumpers initially, but when you said they were limited to 10A I looked up the device in question, and shared its statistics.
So, it would work, it would only take a hundred times as long. My family had a thirty-minute conference call during my lunch break, which I can summarize in two sentences. If I can give enough information in eighteen seconds, is that 100 times as good as taking half an hour? |
The description was inaccurate too: Quote:
1 Attachment(s)
Guys! We have been working too hard! Just use this!
http://ecomodder.com/forum/attachmen...1&d=1518113980 https://www.amazon.com/Eurow-Quick-J...70_&dpSrc=srch The thing is, it looks terrible, but are those cables actually enough? I would want to review it, but not without free shipping. This one looks better, cheaper, and is Prime, but only has a four-foot cord: https://www.amazon.com/Schumacher-SA.../dp/B000H92L4W I would purchase this if it was longer than four feet. What would I do with it? I do not have any idea! https://www.amazon.com/Cigarette-Lig.../dp/B01MYRV6PE There is some convenience to not popping the hood, but needing ten minutes to adequately charge a weak battery? What about a completely dead one? |
Four feet huh.
One end goes into the cigarette lighter socket, but the other end? https://www.duracell.nl/app/themes/d...ny-history.png |
Speaking of jumper packs, this just appeared for $35 on Slickdeals:
https://www.amazon.com/gp/product/B0...UZC6UH73&psc=1 Use code AUKEYBC1 to get it for $35 12 Ah and 400 CCA https://images-na.ssl-images-amazon....L._SL1500_.jpg |
Arguments are getting pretty rowdy on SlickDeals.
All sold out! Buy 3 and get a decent ebike battery for $100...
