Old 04-30-2019, 06:55 AM   #1 (permalink)
Towing With A Gen III Prius. Have You Done It?
Any problems with the Prius?
Old 04-30-2019, 12:09 PM   #2 (permalink)
90 day: 29.78 mpg (US)
https://ecomodder.com/forum/showthre...tml#post548976
https://ecomodder.com/forum/showthre...tml#post556816
Xist (05-04-2019)
Old 04-30-2019, 12:26 PM   #3 (permalink)
Thanks, Redpoint. We've made a 4000 mile round trip with the Prius loaded to the gills with loaded U Haul boxes, and this trip is planned using about 2/3rds of those boxes (and less than 200 pounds of trailer and carrier box). I know the car's suspension will be less taxed by moving the load to a trailer. I just wanted to know if anyone has experienced any mechanical problems with the drive train doing what Toyota says is verboten.
Old 04-30-2019, 12:37 PM   #4 (permalink)
I would probably try to fit everything interior if you can, and it doesn't exceed say 1,200 lbs. It's extra strain on the suspension, but less strain on the motor since a trailer ads aero drag.
If you go with a trailer, Filling the box to the top or covering it will make it much more aerodynamic and put less strain on the motor.
I've pulled jetskis maybe an hour away on winding roads with no issue, and compost dirt only 10 minutes away with no issues.
What are you pulling?
Old 04-30-2019, 01:34 PM   #5 (permalink)
It won't be an open box. I have an X Cargo 20 cu. ft. cartop carrier I plan to mount backwards on a 40 x 48 Harbor Freight trailer (stretched to 40 x 67 to undrlay the whole carrier) Much like this drawing. I'll mount the tongue as short as possible to allow full lock turns without hitting. (I will park where I don't have to back up.)
Name:	Prius and Carrier Trailer.JPG
Old 04-30-2019, 02:14 PM   #6 (permalink)
That will be cake to pull. How much total weight are we talkin?
Old 04-30-2019, 02:24 PM   #7 (permalink)
Don't know, yet. Haven't packed. Might be a good idea to do that and weigh the cargo.
The trailer is about 150 Lbs. The carrier is 34 Lbs.
Might do PVC hoops and some kind of smooth fabric to make a conical air divertor forward of the carrier coming to a point just behind the coupler.
Old 04-30-2019, 07:53 PM   #8 (permalink)
Air over a tarpaulin or whatever has problems (buffeting). A vertical wall between the tow vehicle and the trailer will block crosswinds. Vortex traps in the lower right:
Old 04-30-2019, 11:14 PM   #9 (permalink)
90 day: 19.36 mpg (US)
The load in the trailer always trumps putting the same load in the car.
And they DONT say it’s forbidden. Only that they cannot recommend it. Big difference.
The easier the road (Interstate) the less it would concern me. Tires on the car will heat higher than those on the trailer. That’s normal.
As the trailer presents no forward wind load of consequence, it’s only the crosswinds. Natural & man-made.
Choose your routing. Post it. There’s always meat on that bone.
Old 05-01-2019, 01:11 PM   #10 (permalink)
Yes, I should find a flexible material, such as that used for kitchen cutting pads. Something light that would bend around a vertical post near the and triangularly fill the gap between the carrier and the car. OR, I
could do it with two pieces of 1/4" plywood.
