EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Scaling the Template (https://ecomodder.com/forum/showthread.php/scaling-template-25975.html)
Xist 05-24-2013 06:47 PM
Since an argument developed on Blowncopcar's thread http://ecomodder.com/forum/showthrea...kay-25809.html, and this argument did not actually involve Blowcopcar, I am copying and pasting the posts and then some from http://ecomodder.com/forum/showthrea...tml#post364651. I actually had the same question.
To my friendly neighborhood moderators, if I have made a mess of things, please feel free to delete or edit this message, especially if it would be easier to do this properly.
I am starting at page two of Blowncopcar's thread, post #21:
Originally Posted by kach22i (Post 372207)
To clarify even further, of course the transition should be gradual.
Taking the images posted and estimating with an adjustable triangle on my computer screen, we can see that the angles of inclination do increase.
Automobile 2 - Odds And Ends Photos by kach22i | Photobucket
http://i184.photobucket.com/albums/x...psf7875766.jpg
I think there is a matter of scaling to consider which we should not leave out.
Say for instance we mount a 1/6 scale model of the car to the roof of the full sized car. The Cd of the model should be close to that of the full sized car without the roof attachment, right?
The frontal areas of the full sized car and model will be dramatically different, but the Cd's should be similar.
Now for argument's sake, graph on a "known to work" roof transition without regard to scale.
http://i184.photobucket.com/albums/x...ps6b4c71a4.jpg
My hypothesis here is that when thinking about "scale", be it for a more aerodynamic mirror, roof luggage, trailer or an entire car body, we may have far for liberties at hand than normally accepted following the template at the standard scale.
What the Geo Metro and Pontiac Firefly roof garnishments prove to my eyes, is that re-scaling principals are already being applied, although nobody is calling them that just yet.
Originally Posted by ChazInMT (Post 372259)
Yeah...No.
I thought the same thing once.
At the end of the day, we're not running scale models through the air, we're running full size cars. The Template is designed to be under the wheels and at the top of the highest point of the car, because that is what the gross volume of air is being affected by. Garnishments will obviously affect the overall shape and thus the Cd, but we cannot shrink the template onto small features and do elemental analysis on them to see if they'll optimize the entire shape.
I had a hard time with this myself a few years back and really thought as you do, and when I came to the realization that I was wrong, it sort of set a good fundamental understanding of aerodynamics for me which has not changed since. This whole conversation took place HERE.
Of course it is entirely possible that I just misconstrued what you were trying to say, and if so I apologize. These are good talking points worthy of hashing out for sure if we are to come to a good understanding of how to optimize the shapes of our vehicles to reduce drag.
Oh, and the Reynolds Number, which I'll admit is a bit of a mystery to me in detail, but the basics of it state that: A 1/6th scale model may indeed have a very different Cd than the full sized version. That's my take away, maybe someday I'll edumacate muhself on the vagaries of it, but for now, I'll just understand it to know that scale definitely changes things.
Originally Posted by kach22i (Post 372312)
Interesting, thank you for providing the link.
An important goal indeed, but in this situation he (the original poster) wanted the flow to stay attached. Maybe his goals should be re-examined.
I will look into this.
Below is an example of what I had in mind, not saying it is the best thing to do to obtain an aero-design. Just saying if adding on, maybe scaling down the template is better than nothing at all.
18 Gurney Bubble $35
Cushman Competition
http://www.cushmancompetition.com/GT...y_Bubble_1.jpg
Panoramio - Photo of Gurney bubble on a GT40
http://mw2.google.com/mw-panoramio/p...m/65873497.jpg
Reproduction GT40 for sale in California - SB100 *SOLD* - GT40s.com
https://lh6.googleusercontent.com/-q...0/DSC_9926.JPG
Originally Posted by ChazInMT (Post 372447)
You misunderstood me I think. I am saying that attached flow will always be required for the ideal aerodynamic car, but, It is a consequence of good design, it is not the main goal. Everyone gets all hairbrained about attached flow like that is the only thing we need to accomplish in order to achieve aerodynamic nirvana, but it is not. Of course he wants attached flow, he probably has it now, but just because the flow is attached does not mean it is optimized. You need to carefully consider how fast the air is being asked to close in behind the shape, if it is too fast, it creates low pressure. If this low pressure is in close proximity to an area of high pressure, the air will move up from the high to the low and if strong enough a difference, will set a vortex in motion which will be a real drag.
And Yes, If you have something sticking up on a car, a mini template is the best way to mitigate the damage done. I always look at AC units on RV roofs and think "That should be mini-templated". But, when you look at the major structures of cars, like the trailing edge of the roof, you can't just start with a mini-template there and expect it to be optimal, it probably wouldn't hurt, but it won't minimize the drag for the space that it takes up.
Again, I'm not saying here that the existing Kamm is a disaster, just that it is not optimal. It is giving back 60-70% of the potential gain for a structure of it's size and type when it could be doing 100%
Originally Posted by kach22i (Post 372492)
This is how my roof wing (see link in signature) works.
I had not really considered that if drawing too much air downward via pressure differences that a large drag causing vortex could be formed.
To tell the truth, it is difficult to see large trailing vortexes in wind tunnel smoke streams.
And CFD models mostly look like irrelevant swirls of psychedelic colors to me.
The CFD models based on pressure (verses flow) are even more ambiguous to my eyes.
Essentially everything aft of the car just looks like a mess to me, but I am slowly learning the differences.
Originally Posted by Sven7 (Post 372545)
Just, whatever you do, please refrain from scaling the template like this. It will just confuse others and help to concrete bad habits in others. If you're unsure how to use it, re-read this thread.
Not trying to get all down on you or anything. I just want to make sure that the info we're posting is going to be useful to others who may happen upon it.
Originally Posted by Xist (Post 372557)
How much for a Hammond bubble? http://db2.stb.s-msn.com/i/D2/76415F...5D3EC99A7E.jpg
Sven7, who made that image? Did you properly discipline them?
Originally Posted by kach22i (Post 372639)
When you say useful, you mean following conventional wisdom, right?
As pointed out in this thread there are several Japanese hybrids which truncate the arc over the roof at a greater angle than "our template". The reason for this is still being debated, and that debate is healthy in my opinion.
Back when we talked about altering the roof of a +2005 Mustang to fit the template the idea of re-scaling the template for the canopy somehow gained more acceptance than in this thread.
My goal in examining the re-scaling of the template is to discover the exceptions to the rules, not to redefine the rules or aero template.
There is something to be learned here, I just haven't quite figured out what yet.
The Gurney Bubble, wheel blisters and so forth are part of a micro aerodynamic package inside/outside of the overall general aero template.
How large is "micro", and may it include an entire passenger cabin canopy?
Still learning the answer to that one.
Originally Posted by Sven7 (Post 372652)
Those interested in Geo Metro Kammback advice can skip this post.
I take it Conventional wisdom would be the culmination of decades of aerodynamic research by seasoned professionals? Then yes, I would suggest sticking to conventional wisdom.
Yes, we do know each car is designed and modified on a case-by-case basis, HOWEVER, major changes such as the ideal angle of the rear glass are taken on by seasoned professionals in full-size wind tunnels in huge design and engineering facilities. They are tested and re-tested. They are built from the ground up to be a cohesive form.
Adding a kammback to an existing car without wind tunnel testing is an entirely different beast and we need to play it safe, using tried-and-true methods and forms in order to make things work as well as possible. We need to build off of known values and "conventional wisdom" to be reasonably confident the things we build will work as intended.
Throwing your hat in the ring because you think maybe unconventional changes might work in the right circumstances is not productive in this thread. Don't post an unfounded opinion as some sort of "alternate" fact.
Until you test these theories and exhibit some form of real-world expertise on them, please refrain from posting them in otherwise serious threads. Moving drawings around in Photoshop does nothing to advance aerodynamic theory and only serves to confuse those who don't know better.
If you haven't learned what you're trying to learn it might be good to learn it before trying to teach others.
We have the Unicorn Corral for spitballing about this kind of stuff, and I personally think that's where this "debate" should stay. Until it's proven.
Until then, we have no reason to believe that the template is not serving its intended purpose. We have no reason to discard it or modify it. Next time, if you're thinking about using the template improperly, just STOP and think about what you're doing.
Just follow WWJD (What Would Jaray Do). Imagine having to explain to Paul Jaray why you're doing what you do. Saying "it looks like it'll work" or "why not?" isn't good enough.
Originally Posted by Sven7 (Post 372654)
Kach22i.
Seriously, we do airflow testing here at work and some stuff comes out the exact opposite of what you'd think. I obviously can't go into detail. Just be aware that in many aero circumstances, how a thing looks has little bearing on how it actually works. If you're trying something that deviates from conventional wisdom, you need to test it.
Originally Posted by Xist (Post 372664)
Can you give me any examples? Just whisper into my microphone--I mean, my ear!
I think that it was Aerohead that said that in a windtunnel, the air going over the trunk of a 914 actually flowed forward!
Stuff like that?
I have seen this diagram several times lately and when Aerohead shared it in http://ecomodder.com/forum/showthrea...rag-25845.html I responded:
and he answered:
http://i1271.photobucket.com/albums/.../drawings2.jpg
You guys seem to have agreed that attached flow is not enough, but would you have even that much if the angle is too steep?
Originally Posted by kach22i (Post 372706)
Tyler, next time you feel like coming off as some snotty kid and know it all, just stop and think about it - seriously.
There have been several recent postings on the late 1970's and early 1980's work NASA did at out at Dryden. It's information like this which investigates things outside an idealized 3D shape which I find most useful to our DIY backyard applications on real world vehicles.
http://i184.photobucket.com/albums/x...ps2aae42fc.jpg
http://i184.photobucket.com/albums/x...ps468f9c5b.jpg
The Dryden truncated boattail has been discussed many times in this forum without anyone suggesting the that template is in error. I don't see why it cannot be done again.
One of many NASA/Dryden PDF's posted in the forum:
Access forbidden!
Photo Gallery on several of their research projects"
NASA - Dryden Image Gallery
EDIT-1 ............image added:
http://i184.photobucket.com/albums/x...psb4f53ba8.jpg
Originally Posted by aerohead (Post 372708)
If the contour is steeper than the 'Template' it puts the boundary layer in a very precarious position.The sudden pressure rise will trigger separation and your wake begins right there,with a tremendously low base pressure,killing you with pressure drag.
The 1922 Klemperer' streamlined brick runs a 'fast' rear contour but it won't go below Cd 0.15.It's right at 22-degrees and it gets there pretty fast.
Originally Posted by ChazInMT (Post 372721)
Kach, apply the template however you want for yourself. When you apply it wrong in open forum, don't expect us all to fall all over ourselves heaping praise on you for your insightful genius. I have patiently tried numerous times to explain where your thinking is in error. Your post #33 is proving to me that you disregard what I say and are unwilling to listen to anyone but yourself. I'm done trying to help you.
Originally Posted by kach22i (Post 372766)
ChazInMT, I never said that you were wrong, Tyler was wrong or the aero template was wrong - remember that.
I've stated that rescaling the template for smaller scale protrusions like the Gurney Bubble works and achieved agreement.
The earlier +2005 Mustang example also caused some people to rethink how the template could be interpreted.
The trailing edge roof spoilers on econoboxes and the roof garnish on pick-up trucks also seems to be cases where increasing the angle of inclination over that of the aero-template (at full scale) works.
At some point you have to admit my discovery of a connection between the template and rescaling has validity. One size in fact does not fit all.
You have seen and noted several Japanese hybrids veering from the idealized 3D aero shape at least in profile, and this raised a question. This very question I have attempted to answer with rescaling exercises.
If you cannot see what is before you, then you are surely blind.
http://i184.photobucket.com/albums/x...ps04978180.jpg
How much more obvious can I make it?
The aero-template works.
Rescaling the aero-template works to some degree, but it is not the maximized application of this tool.
EDIT-1:
A more detailed examination of this body style and rescaling of template.
http://i184.photobucket.com/albums/x...psb93382f1.jpg
Originally Posted by Sven7 (Post 372845)
I try reason and it just bounces off. I'm going to try one more time. This is the last one.
-Gurney bubbles and trailer A/C unit are not applied to the trailing edge of the vehicle.
-New hybrids are designed as entire vehicles, where the designers are able to tweak and test virtually any part or surface of the vehicle.
-There are more factors in overall Cd than the center profile. Tumblehome, mirrors, plan taper... many if not all of these are adjusted and tinkered with in the design phase of high-efficiency cars.
-The only thing the OP is changing is the trailing edge of the greenhouse.
-You're taking a lot of liberties with the NASA truck, suggesting in one image that it is simply 22 degrees and in another that it matches a scaled template.
-The Volkswagen Golf was designed in the early 70's and was by no means an aerodynamic masterpiece. Picking apart the exact curvature from a non-orthographic image is pedantic.
-I've listened to reports from the aero lab at work and can tell you the car needs to be considered as a whole, not just some 30cm long segment on the back of the roof.
Yep.
Originally Posted by Sven7 (Post 372876)
Not yet; you'll want to do this. Seven degrees on the top. :thumbup:
http://i41.tinypic.com/ayubuq.jpg
And yeah, the longer the better. When you revise it post up some more pics!
Originally Posted by Xist (Post 372892)
I will repeat that filling the wake seems to provide benefits, but should not achieve the full potential.
Originally Posted by kach22i (Post 372993)
I don't think you are that unobservant, so I have to assume you enjoy being a spit wad. In one image I show it does not exceed 22 degrees, in the other that it's a close match for an extremely scaled down version of the template.
Is this what you would rather see?
http://i184.photobucket.com/albums/x...ps8e809ac3.jpg
Kind of makes my point and not yours, don't it?
Close enough to a true side view to make my point, I don't see you providing a better image.
I would agree, but this is not an attempt to design a from scratch car body is it?
Here is a thread in which several early discoveries were made leading to my current perspective on things.
http://ecomodder.com/forum/showthrea...ign-18632.html
A response:
Mind you that I was not and am not in 100% agreement with winkosmosis, but taking what he had to say about the importance of attachment can certainly be applied to a scaled down version of the template. We are probably saying the same thing just going about it from a differing perspective or using a different choice of words.
The proof is in the numbers (Dryden Truck and Porsche Cd numbers).
EDIT-1:
http://i184.photobucket.com/albums/x...psc55a137f.jpg
Originally Posted by aerohead (Post 372998)
I would comment that the NASA' Dryden Econoline has twice the drag of the 'Template.'
The Porsche would see a 57% drag reduction.
Neither vehicle could get there using what NASA or Porsche used.
If 0.238 and 0.28 were the ultimate goal,then NASA was able to squeak by Carl Breer's 1934-1/2 DeSoto Airflow,and Porsche was able to match Edmund Rumpler's 1928 Tropenwagen.
Both a great success!
Originally Posted by kach22i (Post 373001)
When you scale down the template, you scale down your success.;)
I have a new catch phrase.:D
Stock Porsche 911.......................................0.28 Cd
Porsche completely redesigns the 911 Carrera
http://images.gizmag.com/hero/porsch...11-carrera.jpg
http://ecomodder.com/forum/showthrea...1-a-13538.html
(1) Standard DeSoto Airflow sedan----------- Cd 0.546
(6)............................Full experimental aero: Cd 0.238
http://ecomodder.com/forum/attachmen...p;d=1277572689
More than one way to get there?
Rumpler Tropfenwagen: Description of the model, photo gallery, modifications list ...
http://encarsglobe.com/data_images/m...enwagen-02.jpg
http://ecomodder.com/forum/showthrea...-6-a-2670.html
Xist 05-24-2013 06:56 PM
From http://ecomodder.com/forum/showthrea...tml#post364651
Originally Posted by Xist (Post 364651)
For a given body moving through air, does the air itself care the size of the body?
Originally Posted by aerohead (Post 364849)
As far as size,the air doesn't know the difference (My Fortran IV professor would kill me for saying that).The air velocity must match such that 'dynamic similarity',or,'verisimilitude' exists for the body as far as Reynolds number is concerned.
If you found a boat hull which at the height of the Prius,happened to match the contour of the 'Template' you could use it for an 'ideal' body.And narrowing would be a must.
I've tried this with the full-boat-tailed trailer project.You'd want to find a better 'candidate' boat than the one I used.
The only parameter that's critical is the overall height above the ground where the body will be the tallest.Everything is scaled from there.
So with the go-kart,you'd probably use the top of the rollbar as your 'peak' and go from there.But bear in mind that you've got to have 'clean' air coming at the tail,so the kart would have to be completely enclosed for it to function.
I have a 21-foot sailboat hull which will become a 5th-wheel RV trailer.
If I live long enough to do it.
Sven7 05-25-2013 01:02 AM
Thanks- I'm curious to see where this goes.
Far as I can see, we kind of left off saying that scaling the template will still be better than no template at all, but will not achieve full aero benefits. Are there some instances in which scaling the template would result in ideal drag reduction?
PS- feel free to delete all my stupid argumentative posts in the metro thread.
Xist 05-25-2013 06:11 AM
Originally Posted by ChazInMT (Post 373056)
We were arguing?
NachtRitter 05-25-2013 12:52 PM
Looks good to me...
kach22i 05-26-2013 10:32 AM
Xist, thank you for taking the time to compile these collections of posts.
The Aero template is a tool, designed to be used a certain way for best results. It is meant to overlay on a car with the high point on the top of the car at its highest point, and the bottom chord at the bottom of the tires.
I have to slightly disagree ChazInMT, the template is for an idealized 3D shape, and the way it's often used/abused in the forum is in 2D profile only with little consideration for the resulting vortexes. And when used, it is affecting only the upper aft canopy above the tires or pick-up truck bed.
I've explored this issue from several angles in an attempt to gain a better understanding, going from a 2-part body to a 5-part body. See thread linked to below.
http://ecomodder.com/forum/showthrea...tml#post292262
The very idea of adding mass/frontal area to a vehicle such as the type above to meet an idealized template requirement which is not specific to this vehicle's task runs counter to common sense to say the least. And begs the question: then why try it to a common road vehicle?
If there is another way to enclose the wheels of this car without adding mass (area), I'm open to suggestion.
As mentioned in the 2012 Mustang verses the 1978 Escort thread, the frontal area is as important as anything else affecting the drag.
Auto Union Type C Streamline
http://www.motorabilia.biz/models_(1).htm
With a drag coefficient (cd) of just 0.24 it is better then the Mercedes Benz Streamliner with a cd of 0.25.
kach22i 05-26-2013 11:14 AM
A cut & paste from the 1936 GM thread:
Originally Posted by aerohead (Post 373004)
If you inspect Hoerner's 'AERODYNAMIC DRAG',his treatment of canopies and blisters(pontoon fenders and separate greenhouse) actually goes in the other direction.
Instead of a 5:1 fineness ratio,he'll recommend 10:1.
It has to do with interference drag and super-velocities created by these individual elements when placed in proximity to one another.
This is a reason for keeping the aerodynamic 'singularity' of the 'Template' half-body rather than 'combination-forms.'
Since the half-body doesn't allow separation and produces minimum shear it's virtually unbeatable for a door-slammer.
In short, if you scale down the template, count on making it twice as long.................if it's next to anything else.
Sven7 05-26-2013 05:12 PM
1:18 Die-cast Model cars and bikes Perth, Western Australia. CMC, Exoto, Carousel 1, Maisto, Hotwheels.
May I ask what prompted you to talk about adding frontal area?
I made a thread a while back specifically asking about the interaction of templates, from elevation and plan views. Essentially, we learned that one should apply the elevation template as instructed, and use another full teardrop in plan view, scaled to the vehicle's width. Intersect these forms and throw on some radii, mix well and bake at 350 for 20 minutes.
This is the image that went with it.
http://farm9.staticflickr.com/8080/8...c3102af2_o.jpg
They way I read that is this: air speeds up when going around an obstacle (the car). When there is another obstacle on top of the main one (a hood bulge on a car, etc), that already accelerated air is made to go even faster to catch up, necessitating a longer teardrop form.
So, are we to believe that if you were to scale down a template to, say, cover an RV's air conditioning box, that you would also have to make the template twice as long as normal compared to its height?
Sven7 05-26-2013 05:28 PM
According to that, this would be correct? Am I interpreting that right? Phil?
http://i43.tinypic.com/2uiuou9.jpg
freebeard 05-26-2013 06:58 PM
We were arguing?
http://ecomodder.com/forum/member-fr...jckco1-500.png
Needs a 1/36 scale model attached to the roof of *it*...
Xist 05-26-2013 08:38 PM
1 Attachment(s)
Freebeard, what did the moderator tell Billy Madison? :)
Sven7, before creating my Forester boattail thread, I created this picture:http://ecomodder.com/forum/attachmen...0&d=1369614919
and then posted this one:
http://ecomodder.com/forum/attachmen...5&d=1367238665
Whether or not the template scales, I believe that we can start tapering in the bottom as soon as possible behind the rear wheels.
Sven7 05-26-2013 09:42 PM
Oh, sorry, I did that too on the Anal Probe. The point of my RV post was the scaled template on the roof of the RV. :)
ChazInMT 05-27-2013 01:41 AM
The bottom of the boat tail should not exceed 10° from what I've seen in ecomodder a bunch of times, so your template under the template thing isn't really a good idea.
freebeard 05-27-2013 01:45 AM
Xist -- "...and may God have mercy on my soul?"
...as soon as possible behind the driver's feet.
http://ecomodder.com/forum/member-fr...wu5wo1-500.jpg
Xist 05-27-2013 03:49 AM
When I posted my pictures, Aerohead wrote:
Originally Posted by aerohead (Post 368955)
I'd maintain the upper curvature as you have it,but for the lower,it will depend on where you begin your diffuser.So it's angle will be 2.5-degrees,or around 4-degrees depending,and you can ignore the red line since you have so much ground clearance to begin with.
You may want to do it in 'installments',to see how you like parking 'n such.If you think you can live with more length then go for it.:)
I did not try to figure out what that meant since I only shared the images for entertainment. I guess that I was the only one that thought that it was funny.
I usually am.
kach22i 05-28-2013 11:34 AM
Most of the time when we get a nice flowing canopy on a car such as the +2005 Mustangs or the F-Body Camaro's we in the forum can generally agree not to mess with it in an attempt to Kammback it, because close enough is good enough, right?
Is the below VW XL1 an example of this?
http://i184.photobucket.com/albums/x...ps4101e6b2.jpg
I suspect there is an algorithm or something which can be used when scaling down the template to conformity, in essence saying (by a measure of scale), that when you scale down the template you scale down your measure of success by "X" amount.
Either that or by measuring the volume or space not within the template 3D shell, one could calculate the percent or an actual number one will suffer losses as compared to the ideal template.
http://i184.photobucket.com/albums/x...psa70da726.jpg
I don't need anyone to agree with me with what I see in these exercises, I know what I see. I will however eventually find the answer or the reasoning over time for what I see in these exercises.
So far the reasoning given by others or excused in absence leaving me to wonder, is not satisfying at all.
In my humble opinion, one cannot, and should not attempt to 2D fit a 3D template, and certainly one demanding more explanation than simply lining up with the highest point on the roof as this one.
NOTE: I used the two best images of the XL1 which I could find, one seems to have a slightly longer nose.
Will someone please post the Cd number the idealized 3D aerodynamic Template-C is supposed to give us?
kach22i 05-28-2013 03:56 PM
Originally Posted by ChazInMT (Post 373482)
Thank you, I was using the version with the person standing next to it, but it was not "official" from what I was reading. In addition, there is now an even newer version with a more sloped windshield area, and that looks to be a work in progress as well.
Oh. And you still can scale the thing if you want, and you're right, you'll probably have attached flow when you do scale it, but it won't be an optimized shape.
The template is a guide to optimize the shape of an Entire Vehicle, because when you scale it to fit, the top line of the rear portion automatically becomes the ideal shape the air likes to see for the least overall resistance taking into account the form drag and the skin drag.
I cannot argue with a thing said, it's pretty much what I've been trying to convey as a matter of fact.
And most cars are flat on top for 4-6 feet across, making them something of a wide 2D shape, so you may wanna think about that before you muddy the waters with a 2D vs 3D thing. If you want to build a trike or bike, then you may not be able to make much use of the template because they are taller than they are wide.
The template overlay studies most people post are still in profile only, once in a while get posted in top view, but typically much later if at all. I'm sure that I'm guilty of the same thing here as I did not show the top view of the VW. It's an important issue, to remember in my opinion as real life is in 3D - and so are vortexes.
Finally, 0.13 is the ideal Cd for a vehicle following the template.
Found it here
Thank you ChazInMT, some of this information get buried very deep in the threads. I see that the most idealized number is only 0.08 without wheels and scraping the ground.
There seems to be room for improvement on the VW, 0.189 verses 0.08 of the ideal shape.
aerohead 05-28-2013 06:19 PM
correct?
If the vehicle is taller than it is wide,I would consider treating it as a 'section' rather than a 'half-body.'
For the 'section' the plan-view taper would determine the streamlining.
In plan-view you would mimic the contour of the lowest drag 'section',then pattern your roof contour to mimic what you arrived at for the sides.Somewhere (maybe in the 'Full-boat-tail 'trailer thread is the drag table for 'sections.'
If the vehicle is wider than it is tall,then use the 'Template'.
If you're interested only in limited length,with absolutely no intention of future additional drag reductions,then consider the Wolfgang Klemperer streamlined 'minivan' of 1922.NASA's Dryden Research Center Econoline boat tail has this profile.It's what I did on the VW Transporter in college without knowing it.
Klemperer measured Cd 0.16 for the wind tunnel model.It looks like Hucho or Rolf Buchheim re-tested the same model for the VW 2000 project and measured Cd 0.15.
The hitch is that the vehicle must look exactly as Klemperer designed it and it is very doubtful that you'd be able to see out of the car.
Hucho ran into this problem and VW had to morph Klemperer's shape so much that they ended up with only Cd 0.25.
This is why I stay away from it.
aerohead 05-28-2013 06:40 PM
scaling the 'Template'
*The 1/6-scale model would not have the same Cd as the full-scale car until 120- mph due to the Reynolds number effect with the boundary layer.
*The 'Template' can only be applied as is shown.It is absolutely contextual.The alignments must be at identical scale and position.
*For canopies,blisters,tanks,radomes,nacelles,etc.,you should consult 'AERODYNAMIC DRAG',by Sighard Hoerner.It is the book(s) which is most listed as a reference for such specific information,including Hucho.
*When 'combination',or,'composite' body structures are pieced together,the interaction of each component can create 'super-velocity' effects upon adjoining components and their aerodynamic characteristics are altered by the interactions.
The 'Template' would in no way be appropriate for designing such structures.
If you're interested in only limited 'low drag',then there are many options.
The NASA Dryden van would be one.This design would be patterned after DOT vehicle length and other restrictions.It does not reflect an 'ideal' solution,just an arbitrarily optimized one.
kach22i 05-29-2013 10:57 AM
Originally Posted by aerohead (Post 373520)
..........the Wolfgang Klemperer streamlined 'minivan' of 1922.
In my search to find images of this vehicle I found an intersting website.
Concept Cars and Aerodynamics, 1917-1940
by PETE on MAY 2, 2013
http://www.velocetoday.com/wp-conten...i-Kel-lead.jpg
Still no signs of the Klemperer in question.
EDIT-1:
Seems to me like there are very limited opportunities to apply the template to existing and typically flat sided (and rectangular wheel layout) automobiles.
I don't think that I'll even bother considering these limitations, as it will never be perfect. Anyone who does a template overlay must be a misguided fool and totally ignorant to boot, right?::rolleyes:
http://ecomodder.com/forum/showthrea...c-9287-13.html
Originally Posted by aerohead (Post 221943)
Here's something to consider.
*The lowest Cd for a streamline body of revolution in free-air is 0.04.
* The Template,in free-air,has Cd 0.04.
* When the Template is 'split' in ground-reflection it is Cd 0.07
* When the 'ground-clearance' is cut away from the 'half-body' the Cd is 0.08.
* When skinny wheels are added to it the Cd jumps to 0.12.
* When wheel fairings are arranged around the wheels/tires,the Cd drops to 0.089.
http://ecomodder.com/forum/showthrea...c-9287-47.html
http://ecomodder.com/forum/member-te...-boat-tail.jpg
Originally Posted by freebeard (Post 353489)
If you're up for it, try the Squircle. That's the one in the middle here:
http://i.imgur.com/6EYZT.png
Is this the official Part-C aero-Template Cross Section?
http://en.wikipedia.org/wiki/Squircle
http://upload.wikimedia.org/wikipedi...ircle2.svg.png
I've always assumed the Part-C aero-template would look like this (see image below) in front view, but I'm still looking for it.
http://www.thetruthaboutcars.com/201...n-three-parts/
http://images.thetruthaboutcars.com/...-FrontView.jpg
kach22i 05-29-2013 09:22 PM
I was taking a walk today and noticed an original Audio TT, one without the rear spoiler which they added after the first few months of sales. Apparently the rear lift could be dangerous under certain conditions and they sought to limit lawsuits, so they gave and installed the spoilers for free and retrofit them to cars.
My thoughts went to....well you have to have airflow for a spoiler to work, so they at least had good airflow.
http://i184.photobucket.com/albums/x...psaa9c217f.jpg
This will make me no friends here, but screw it, I'd rather be right than popular. The template is not a religion to me, and cult followings make me nervous.
Add to the fact that the template is not 3D, and I might be a bit miffed about it in retrospect.
How can you have meaningful exercises based on a 2d shape anyway?
The larger you can make the template on your vehicle the better. A full 100% scale is best, but sometimes (most times) some scaled fit is better than nothing at all.
More car wind-tunnel and smoke images are found here:
http://bigmike.marlincrawler.com/for...php?topic=33.0
freebeard 05-29-2013 11:11 PM
That's why I often capitalize Thee Template™; I'm passive-agressive.
The answer to your frustration is the Boxfish
http://i.imgur.com/maVB6.jpg
and maybe the Volkhart-Saggita
http://ecomodder.com/forum/member-fr...ve12d2-042.jpg
Xist 05-30-2013 05:46 AM
Audi TT 1998 - 2006 0.34
Vehicle Coefficient of Drag List - EcoModder
freebeard 05-30-2013 11:44 AM
ChazInMT -- ...if that's what your name really is. If he crossed a line in those 2 posts he was dragging me along with him. "Squircle"
This now makes you a troll, your last posts are clearly in the realm of trolldome and have been reported as such.
Troll! :)
MetroMPG 05-30-2013 03:35 PM
Kachi - considering the accumulated evidence & studies presented to explain and refine The Template (TM), calling its application "religious" or "cultish" is simplistic and disrespectful.
It's fine to question things, but please try to be civil while participating.
freebeard 05-30-2013 04:03 PM
Batman Jr. has spoken. I apologize ChazInMT, ', or whatever your real name is.'
My eye slid right over those bad words. It's OK to say Squircle, right?
MetroMPG 05-30-2013 04:07 PM
Just to be clear: I really don't care if someone wants to question the thinking behind the aero template. How that's done is the issue. That's all.
PS: Squircle is borderline heresy. Very dangerous.
(I kid.)
aerohead 05-30-2013 05:14 PM
comparison
I think it lines up great with the 2nd Gen Aero Template.
http://i43.tinypic.com/658krk.jpg
Bigger Version
Here is a comparison of the old template (Green Line) vs the new one (Red). Aerohead figured out a shorter faster template might be a smidge better if you read what he wrote in the Aerodynamic Streamlining Template: Part C thread.
http://i44.tinypic.com/2ajuewy.jpg
Bigger Version
Here is a link to the new template outline alone in HiRes if you wanna grab it. Made it Just4U.:D
Found it here
Yes,the 2nd-gen 'Template' attempts to rectify 'discrepancies' found when fitting the 1st-gen AST when considering cars like Insight,Prius,XL1.
The difference is subtle but also significant when considering forms.
aerohead 05-30-2013 05:39 PM
Wolfgang Klemperer
For Klemperer's Cd 0.15 -0.16 model :
*Search for Phil Knox aerodynamic photo albums
*go to Book illustrations
*page-1
*Row-5
*2nd graphic from right
*2nd image from top
Klemperer was a graduate engineer working under Paul Jaray at the Zeppelin Werke in Germany who received his P.hD. within a year.
In 1921 Klemperer tested wind tunnel models in the Zeppelin wind tunnel for Jaray and also tested this model for himself.
He measured Cd 0.16 in 1921 and published in 1922.
It appears that Hucho came up with Cd 0.15 with the same model in a modern wind tunnel during the work on the VW 2000 project.
Klemperer measured Cd 0.13 for Paul Jaray's half-body 'pumpkin seed'.Hucho's 1970s re-testing suggests that Jaray's pumpkin seed would be belowCd 0.13. Jaray's pumpkin seed is the premise of the 'Aerodynamic Streamlining Template.'
This form has been used many times for record vehicles.The British are using it this year at Cambridge University for their go at the World Solar Challenge.
aerohead 05-30-2013 06:09 PM
"Template"
EDIT-1:
Squircle - Wikipedia, the free encyclopedia
An Illustrated History Of Automotive Aerodynamics – In Three Parts | The Truth About Cars
*From the side,the 'Template' is half of a teardrop,minus what is cut away to create the ground clearance.
*When the Template is coming at you,you see a semicircle minus the area removed for its 'ground clearance.
*From above you see a full teardrop.minus the area which was cut away for the ground clearance.
The intent of the 'Template' is to provide a safe contour for boat-tailing primarily passenger cars,as they are the majority of vehicles sold.
*based on whatever your starting with,however you can morph it,and integrate it into your vehicle,it would provide a separation-free surface for reducing pressure drag.
As to the overlay,well the problem is that it is perfect.It is the tyranny of singularity.Some people will never lose their attachment to the notion that you'd never find a single solution for drag reduction.
I have some additions I'd like to add to the thread.I've been without transportation for going on 12-weeks now.I hitch a ride into town to come here.When I leave I have a 7-mile walk home.It's a bit awkward to carry materials here and back.
I have every intention to 'complete' the thread.I have no earthly idea when I'll be able to do that.
If you want to depart from science go ahead.You're certainly under no obligation to anyone.Perhaps you'll find solutions elsewhere.
Best to you!
freebeard 05-30-2013 06:41 PM
I've been examining my own actions. The loaded terms slipped right past me, but the name questioning stuck out like a sore thumb to me.
So, we're all good then? How about that Morelli Shape?
aerohead 05-30-2013 06:56 PM
Morelli
Morelli got Cd 0.16 off the ground without wheels.
When he chopped the tail it went to Cd 0.161.
When he lowered it onto the ground it went to Cd 0.35.Ouch!
After a bunch of hours in the Pininfarina tunnel they were able to chisel that down to Cd 0.201 for a 'production-ready' vehicle.'
It was a coup in 1978.
It doesn't seem so dramatic today.
Aptera didn't get any spectacular results with it either.Center of gravity is kinda spooky too!
kach22i 05-30-2013 08:26 PM
This confirms my worst fear about the use and fitting of the template to an existing rectangular automobile and or truck.
Thank you aerohead for the full disclosure and explanation.
We have talked at length about the best way to fit the template in longitudinal section, if I may indulge; how about some pointers on how to use it in cross section?
http://i184.photobucket.com/albums/x...ps12d025f3.jpg
Or this?
http://i184.photobucket.com/albums/x...psb8d012eb.jpg
As a design professional I constantly have to think of things in 3D, and I assumed others on this board were in the same position (for the most part). Frankly, I'm embarrassed that I did not realize before now how absolutely silly using this template in any capacity has been.
Yes, there is more than one way to aerodynamic bliss, but using the aero-template does not appear to be one of them, at least for a non-half round in section vehicle.
Originally Posted by ChazInMT (Post 373883)
Kach has come out and basically called the template worthless in all but a very narrow range of circumstances.
You jumped ahead of me, but this statement is certainly true after today.
I still think as a fully realized 3D shape it works as advertised, and as a guide for transitional curves to the 22-degree limit (scaled down or not) is an excellent guide. Beyond that there has been much misguided silliness with I'm sure nothing but good intent behind it.
The emperor has no clothes.:o
Sven7 05-30-2013 09:16 PM
I'm not going to comment on the bull crap being thrown around. It's not worth my energy. Kach, you obviously would want to get as close as possible to that form when you build a boat tail. This is why we always recommend putting large radii on boat tails. Capiche?
http://i41.tinypic.com/2qk2bmc.jpg
I believe the 1978 Morelli-Pininfarina vehicle you're speaking of is this one:
http://www.cardesign.ru/files/galler...__1280_853.jpg
http://www.cardesignnews.com/servlet...ICE_CONF_ID=68
freebeard 05-31-2013 01:00 AM
Emperor...Citizen? I'm glad you didn't get chased off from the thread. When I first logged in to the forums, the first real insight I received was when I posted this VW Trekker and you improved it.
http://ecomodder.com/forum/member-fr...grid-thing.jpg
I've taken the same journey as you—that's what prompted the 'Does it have to be a half-body...' thread. I was asking how much violence you can do to the template and still have it respect you. Nobody addressed it as I had hoped. My thinking is if the lateral section is semi-elliptical, say as tall as it is wide, then the air movement in section will be faster than the movement in plan; so the taper in plan increases and the taper in section decreases to subdue lateral air movement. How much?
A squircle can range from almost a square (vortexes) to almost a circle (no vortexes). How close can you approach square comfortably?
Sven7 -- "How about that Morelli Shape?" was linked to a thread from 2010. I was thinking about that *thread* more than the design aerohead deconstructed. It ran 19 pages and who appears on page 19?
  • ChazInMT
  • kach22i
  • NeilBlanchard
  • autogyro
  • aerohead
It's like it's coming around again on the old guitar.
kach22i 05-31-2013 10:12 AM
I've done some research into hovercraft ducts where we go from round to square/rectangular in a convergent taper. Building a boattail would be similar in that we would be going from square to round with a convergent taper.
Other than a generalized arc from the template which must be twisted in 3D to even be considered relevant, I see no direct application of the template in long section if the cross section is a total bust.
This is a classic case of trying to fit a square peg into a round hole (half round hole actually), maybe there should be vetting process to avoid such situations in the future.
Sorry, I have failed you (and myself), other forums dedicated to aerodynamics must be reading this and having a good laugh on us all. Like I said I feel embarrassed, and now embarrassed for anyone suckered into this great folly.
I like the aero-template as a concept which I can keep in the back of my mind, but as the tool it was intended to be, it's fallen short, way short in my opinion.
Perhaps a better tool would be a box in section proportioned to a typical road car's length and a typical windshield, then given a "known to work" boattail.
Such a template would be applicable to retrofitting existing cars/trucks, but the gold standard Part-C template could be reserved for scratch built projects with a hemispherical cross section.
Just my thoughts.
freebeard 05-31-2013 12:46 PM
My vote is for prolate ellipsoid.
This is relevant to my interests. You weren't responsible for the other thread, and you should see what passes for aerodynamic speculation on other car sites.
kach22i 05-31-2013 02:15 PM
Originally Posted by freebeard (Post 374015)
......... and you should see what passes for aerodynamic speculation on other car sites.
I know some car sites and design sites (illustration/Industrial design) have some frightful things being posted, which is why I think despite all the friction, this site is head and shoulders above those.
I was referring to sites dedicated to aerodynamics, although I'm not exactly sure if I know of any. Post a few and I'll check them out, a good way to get rid of me - haha.;)
The closest I've gotten to is the Physics Forum:
Physics Help and Math Help - Physics Forums
On the Physics Forum site there is much bleed though into other topics because they tend to look at everything. If you were to post something on aerodynamics or Cd alone without considering other factors such as lift, handling and other fundamentals you will pretty much have to spend some energy getting the one answer you want. However you will learn a lot, and might feel fairly stupid in the end, especially if you have forgotten much of your college studies.
In my own defense, from what I can recall all of my car/truck studies have been 3D in nature, but like I said maybe not when using the template as advertised.
The cross-section is a deal breaker, I should have remembered building all those balsa aircraft models as a young teen. I made a killer 36 inch wingspan Spitfire, talk about ellipsoid (fuselage section and wings).
Similar to this:
Guillow’s Spitfire MK-1 – {part 6} | Monogram F-15 Eagle - 1:48 scale kit
http://popeyesquadron.files.wordpres...2013/04/29.jpg
http://www.rchobbyhub.com/phpBB3/vie...p?f=204&t=3534
[IMG]http://i17.photobucket.com/albums/b6...n/PICT1581.jpg[/IMG]
kach22i 05-31-2013 03:20 PM
Originally Posted by ChazInMT (Post 374033)
All due respect,
Charlie
With all due respect Charlie I have stated the full sized template works as a stand alone entity, but is not the tool needed nor promoted in this forum by it's developers and their following.
I have stated many times in many ways that scaling down the template is scaling down success, and I suspect that there is a mathematical factor which can be applied to this.
I have suggested that a 3D boattail template/tool be develop to retrofit to existing cars/trucks and made suggestion as to what it may look like in cross section and so forth, therefore I have done much more that criticize - read up.
I admit that I need to learn more on the scaling of models (not doing any model testing at this time), however very few things posted in the forum lend a clue. The comment that a 1/6th scale model would need to be doing 120 mph means what exactly? An intriguing comment, one which I appreciate but no context or comparisons to add value or pattern. 120 mph verses what other speed of the full scale body, 20 or 250 mph? No clue, sorry if I missed it. Is the air going to detach on the scale model before the full scale model? Now that would be useful information and make some sense. Crickets.
I understand that one cannot fit a square peg into a half circle hole, which puts me one up on you Charlie - your emotions on this topic have blinded you to the painfully obvious.
kach22i 05-31-2013 07:15 PM
You sure have a big head about yourself Charlie, living in an alternate universe must be hard on you.
Now back to something more productive, pages 24-30-ish have several post by ERTW which is the missing link several people remembered but could not locate.
http://ecomodder.com/forum/showthrea...c-9287-24.html
http://ecomodder.com/forum/showthrea...c-9287-25.html
http://ecomodder.com/forum/attachmen...p;d=1329329422
http://ecomodder.com/forum/showthrea...c-9287-26.html
http://ecomodder.com/forum/attachmen...p;d=1329716015
More than one person expressed misgivings about the template's application and usefulness other than in the abstract. I am not alone on that one.
EDIT-1:
The below overlays based ERTW's work, but I don't have his 3D skills. They should get the point across to even the most obtuse.
http://i184.photobucket.com/albums/x...ps0004be12.jpg
A different fitting attempt to convey the message.
http://i184.photobucket.com/albums/x...ps0c4aa57a.jpg
Close up detail
http://i184.photobucket.com/albums/x...pse9cab00d.jpg
