EcoModder.com
-   Instrumentation (https://ecomodder.com/forum/instrumentation.html)
-   -   scangauge problems (https://ecomodder.com/forum/showthread.php/scangauge-problems-17123.html)
scottoriou 04-30-2011 01:49 PM
scangauge problems
So I just got my scangauge. It isnt coming on. I checked my fuses and they are all good. I used a multimeter and found that I have voltage at the connector. Any suggestions?
euromodder 04-30-2011 05:50 PM
Have you tried both inputs (side and back) ?
Tried pushing the red-circled button ?
Did you find voltage at the car's OBD connector, or on the wire with RJ45 (network) connector leading up to the unit ?
