ScanGauge Tips and Tricks?
The ScanGauge arrives any day now. I've read the manual cover to cover and most of the threads. For you guys that have been using it for while, what do you find the most useful to monitor for your specific driving situation?
I plan on spending the first several days monitoring the right foot and auto trans operation with (TPS - Fuel Flow - MPH - RPM) then moving on to trip dynamics for my common route. Once I have that locked, I'll investigate two new primary routes for the 25-26 mile commute. I've already had good sense enough to trade 12 miles of I-75 for 10.5 miles of 55mph backroads with the addition of only one potential stop. |
I don't get fancy - I simply monitor instant & average MPG (using the add-a-gauge feature to view both on the "Gauges" screen).
L O D
Live in Over Drive.
No... LOD is engine load. I'm not sure how the SG calculates it. I also don't know what formula it uses to calculate MPG, but since the end goal is maximizing those numbers, they're what I tend to look at. |
As stated LOD is the load monitoring feature. It will be quite unique to each vehicle but it gives you a gauge of how hard your engine is working. It is useful for optimizing acceleration and for helping determine how much speed to bleed on ascents and how to regain speed on descents. You try and keep the LOD flat. Most people use the throttle position sensor but I find on a drive by wire vehicle that the the ECM will vary throttle to load anyways, so a steady foot won't help. I tend to be unique in my experience, so it may just be me missing the boat completely, but LOD is the one box in the ScanGauge that doesn't get changed.
Super guys. Thanks for the start! I can build my first Custom Gauge.
From TDI Club (i'm having SGII issues )
It is, yes. If you have the SG2, I believe you can have it re-flashed to incorporate the new code (I think that's what Daox is doing right now). Check with Ron @ Linear Logic.
What car are you using your SG on? |
