Old 02-24-2009, 10:08 PM   #1 (permalink)
Johnny 5 - '81 Honda Cm400e
90 day: 42.86 mpg (US)
Da bike - '06 Honda Shadow Vlx deluxe
90 day: 59.47 mpg (US)
2000 rpm
my friend and i were talking about gear ratios, and some how he said about 2k rpm was the best rpm for mpg. my question was yeah on what size motor.
then he correted and said smaller motors nee high rpm to cruise at tha same hp. well to do 55 mph my 98 taco needs about 40hp.
that got me to thinking what mph are you guys at, at 2000rpm in top gear?
98 4x4 tacoma 2.7 5 speed manual. 59mph@2k rpm
09 4x4 tacoma 4.0 5 speed auto 67mph at 2k rpm
07 camry se 2.4 5 speed auto 63mph at 2k rpm.
if i remember correctly
09 silverado 4x4 5.3 4 speed auto 80 mph at 2k rpm.
Old 02-24-2009, 10:58 PM   #2 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
my civic 1.5 vx 2k rpm I think is right around 60 mph, my old crx hf 2k rpm was around 68mph with the 1.5 engine that put out a peek of 58hp... it's really what it is tuned for, just replacing my civic exhaust made a difference, the old exhaust was larger around and that low end power came back as soon as I went with the stock small exhaust, mileage started to come back up as well even with the cold.
Old 02-24-2009, 11:11 PM   #3 (permalink)
Hi,
IIRC, my xA is only going about 40mph in 5th gear at 2K RPM. To go 60mph, is ~3200 RPM... I need taller gears, and/or a final drive under 4:1.
Old 02-25-2009, 06:25 AM   #4 (permalink)
Custom User Title
Daily Driver - '02 Pontiac Grand Prix SE
90 day: 18.45 mpg (US)
I think my truck is at 58mph or close to. The car I think is 65mph or close to. I know the car runs under 2K at 60mph, and the truck is real close, might even be dead on. Very different motors, very different gearing. The truck runs out much faster.
Old 02-25-2009, 06:37 AM   #5 (permalink)
Ruint Taco - '19 Toyota Tacoma SR Double Cab
90 day: 23.76 mpg (US)
2000 rrpm is just a rule of thumb. The rpm for best economy could vary a lot depending on engine design.
My car gets it's best at ~1600 rpm,
Old 02-25-2009, 08:05 AM   #6 (permalink)
Ryland's Avatar
I've heard that best mileage is close to the peek torque, not sure if this true or not but if you look at the big chilton repair books they give torque for different engines and the range for civics is between 2,000 rpm for the crx hf's an up to 5000 rpm for some of the SI engines, so it so it does vary alot, you can't make blanket statments.
Old 02-25-2009, 08:13 AM   #7 (permalink)
WonderWagon - '94 Ford Escort LX
Last 3: 51.52 mpg (US)
DaBluOne - '99 Ford Escort SE
90 day: 48.97 mpg (US)
DaRedOne - '99 Ford Escort ZX2 Hot
Not just engine design. Toss the same engine in a heavier car (or add three over weight adult passengers - say 250lbs each - to the current car) and the most efficient rpm will be significantly greater than 1600 rpm.
Old 02-25-2009, 08:30 AM   #8 (permalink)
If i remember correctly:
1.1L Fiat Punto (1996 model), 5th gear at 2000rpm = about 40mph.
30 mph is about 1600rpm..
Old 02-25-2009, 10:46 AM   #9 (permalink)
I don't claim to be a master of internal combustion engine wisdom, but coming from an expedition vehicle background the rule of thumb has always been to gear (axles) and/or shift (manual trans) so your most frequent travel speed coincides with the torque peak RPM of your engine. Fuel efficiency for expedition vehicles is important, not as much for financial reasons but because of the distance that may exist between fuel stations.
Old 02-25-2009, 11:06 AM   #10 (permalink)
2k2Prot5 - '02 Mazda Protege5
90 day: 33.82 mpg (US)
i'm also doing about 40 at 2krpm in fifth... it is disgusting. I'd rather be at 60. That's a big difference.
Can low rpm damage the engine? KiaRio2004 Hypermiling / EcoDriver's Ed 24 10-03-2017 03:16 PM
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
What is the ideal RPM to cruise at? Krunko Hypermiling / EcoDriver's Ed 15 05-16-2009 04:11 PM
VX owner needs help. RPM is incorrect. XyKo Off-Topic Tech 5 08-23-2008 02:27 PM
MetroMPG.com mailbag: is lowest RPM really best for max MPG with big displacement? MetroMPG Hypermiling / EcoDriver's Ed 20 01-06-2008 01:00 PM
