EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Scion FR-S vs. Subaru BRZ (drag coefficient 0.27 - 0.29) (https://ecomodder.com/forum/showthread.php/scion-fr-s-vs-subaru-brz-drag-coefficient-25588.html)
Gasoline Fumes 04-17-2013 01:26 AM
The following comes from the 2013 brochures.
The Scion FR-S has a Cd of .27 and no rear spoiler.
http://www.blogcdn.com/www.autoblog....on-fr-s-fd.jpg
The Subaru BRZ Premium has a Cd of .29 and no rear spoiler.
http://file.kelleybluebookimages.com...40x480_d4s.jpg
The Subaru BRZ Limited has a Cd of .28 and comes with a rear spoiler.
http://autosportscar.com/wp-content/...Side-Right.jpg
Is it the difference in the front ends, or something else? The numbers don't make sense to me. Same EPA ratings.
MetroMPG 04-17-2013 08:13 AM
Same tire size across all 3 models?
user removed 04-17-2013 09:19 AM
Antenna.
regards
Mech
Allch Chcar 04-17-2013 09:37 AM
The FRS does not have a .27 CoeF, it is .29. The GT86 sold in Japan with the belly pans and spoiler has the advertised .27 CoeF. The USDM BRZ limited doesn't have the belly pan so it's .28 CoeF. If you look at the brochure for the JDM GT86 you'll see the spoiler is worth 10 points and the belly pan is worth 10 points. Which gives it the sleek .27 CoeF.
Edit: My mistake, it's not in the brochure. It was in another technical article I read. I'll look for it later.
Gasoline Fumes 04-17-2013 11:19 AM
I was suspicious of that .27 Cd. The Scion brochure does show the belly pans being present, so they weren't totally lying, just had the wrong spec and photo.
Those pans are really worth a .01 decrease in Cd? The first picture is apparently the US version. Just a few center panels makes that much of a difference? I might have to reconsider a belly pan! :)
http://blog.perrinperformance.com/wp...el-550x368.jpg
http://www.mann-engineering.com/site...nderpanels.jpg
http://www.japanparts.com/images/Ima...ase=1&no=43930
Tires are all too-big 215/45-17s. Same antennas too. I think the black car's antenna was a victim of Photoshop.
Allch Chcar 04-17-2013 11:55 AM
You mean the JDM car right? One of the things they cut from the FRS was those belly pans.
Eg: Aerodynamics discussion - Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB
I'm not 100% sure on the BRZ Premium or Limited. It's been a few months since I've seen the pictures.
The tires are actually from the Performance package for the Prius, (not available in the US). So even though they are a bit wide, they are LRR. Which is good enough for me.
Gasoline Fumes 04-17-2013 01:17 PM
No, it's the US Scion FR-S brochure that shows the underbody panels. I'm just assuming they copied the wrong info.
Since it's such a good photo of the panels, I'll post it here:
http://img.photobucket.com/albums/09...s/underfrs.jpg
Blue Angel 04-17-2013 01:33 PM
? This is a sports car and you think 215's are too wide? My Cruze Eco has 215/55-17's... a much taller tire for sure but still a 215, and it's an eco-machine. Since my Cruze uses the same size wheel as the FR-S (17x7), my tires are actually wider when measured at their widest point. The Cruze Eco's wheels are much lighter though. :D
The first thing this car needs for better fuel economy is a taller top gear (or a 7th gear), not narrower tires... a manual FR-S is only rated at 30 MPG highway, and a Corvette is rated at 26!
I suppose you could replace those 215's with 185/65-15's and take all the "sports" out of the "car"... assuming a 15" wheel even fits over the brake calipers. :rolleyes:
:turtle:
Gasoline Fumes 04-17-2013 01:43 PM
I actually meant wheel/tire size. I like wide tires and grip around corners. I'd just rather have something like 215/50/15s. Is it wrong to want them on a diesel BRZ? :snail:
Blue Angel 04-17-2013 02:06 PM
A 215/50-15 is only 23.5" tall, that's 1.1" shorter than the already small (by today's standards) 215/45-17 that's on the car. IMO, it wouldn't look very "sports-car like", and isn't that a big part of starting with a FR-S in the first place - the sports car looks?
RE: Diesel BRZ
My personal opinion: It's not healthy to lust after things that we know for sure will never exist! :)
