EcoModder.com
-   Instrumentation (https://ecomodder.com/forum/instrumentation.html)
-   -   SGII backlight not working? (https://ecomodder.com/forum/showthread.php/sgii-backlight-not-working-3122.html)
ch00f 06-16-2008 09:08 PM
I just got my ScanGauge in the mail today and I quickly hooked it up and began calibrating, but as day turned to night, I noticed that the backlight wasn't on.
I went to the lamp setting and tried turning it on high and low and changing the color, but nothing changed. I've tried it while the key was in "on" "acc" and "off" Otherwise, the device is working fine.
The troubleshooting tips said that if nothing shows on the screen and backlight is off, you should replace the fuse. This is pretty obvious, but either way, the normal display is working fine. Could it be that the backlight is on a different circuit somehow? or is my SG just defective?
Is there some trick to getting it to work?
pawilkes 06-16-2008 09:43 PM
good luck. I got my scan gauge 4 months ago and it stopped working the in the last couple days. I am going to try it again tomorrow and then send it back for repair/replacement. I have grown to really like the thing though, I don't like driving without it.
MetroMPG 06-16-2008 09:58 PM
ch00f: sounds like you may have gotten a dud.
ch00f 06-18-2008 03:22 AM
I called them this morning and they are shipping me a brand new unit in the mail with a return box for the old one. This company has amazing service.
