Old 09-16-2009, 11:25 PM   #1 (permalink)
VSS signal for GPS speedomoter
I'm currently working with someone online to develop a gps speedometer that will output a signal that will mimic a VSS. With a VSS output any aftermarket speedometer could be used as well as any aftermarket cruise control. I know there are drawbacks to using a gps as a cruise control device so none of the "that is dangerous don't do it" stuff. What I'm looking for is a recommendation on what kind of signal should the gps produce that would most standard. What would the voltage range be. Would it pulse high or low. and how long would the pulses be. These are the questions that the builder sent me and I don't know the answers as I've never messed around with a speed sensor before. Any help appreciated as I would really like to get this project off the ground.
Old 11-24-2010, 10:49 AM   #2 (permalink)
thefenixgang7's Avatar
Yammy - '78 Yamaha XS750
90 day: 38.98 mpg (US)
Kawasaki - '82 Kawasaki KZ LTD
90 day: 45.94 mpg (US)
Jeep - '88 Jeep Cherokee Laredo 4x4
90 day: 16.42 mpg (US)
F150 - '90 Ford F150 XLT Lariat
90 day: 13.67 mpg (US)
Did you ever have any luck?
VSS Signal assistance? dcb OpenGauge / MPGuino FE computer 33 08-20-2014 12:59 PM
How to Debounce a Geo Metro VSS Coyote X OpenGauge / MPGuino FE computer 20 08-04-2014 10:01 PM
What does an injector signal look like? mhopeng OpenGauge / MPGuino FE computer 10 12-28-2009 01:28 PM
VSS, tach, injector signal logic wikityler Instrumentation 2 07-20-2008 11:02 PM
Signal Generator dcb OpenGauge / MPGuino FE computer 26 06-27-2008 10:29 PM
