SGII, what inputs does it use to compute MPG?
What information does the SGII use to extrapolate the instant MPG and average MPG numbers?
It uses the MAF (mass air flow sensor) in the intake and the VSS (for vehicle speed). By knowing how much air goes into the engine it can use a preset A/F ratio to figure out how much fuel is burnt.
MAF (air flow) for some cars, MAP (air pressure) and rpm for others like mine.
It also needs the engine size. It assumes 14.7:1 air-fuel ratio. |
Backtobasics -
This is what I think is going on : http://ecomodder.com/forum/187883-post20.html CarloSW2 |
I may be beating a dead horse. SGII asks me for engine size, but this is a hiccup. The truck was 5.2, but I swapped in a 5.9 a while back. EVERYTHING on the truck is still 5.2 based, but the block itself. 5.2 injectors, PCM programming, everything.
I use the SGII for instanteous driving feedback, more than anything. I have just learned about the tank fill up options where I can TUNE it completely to the truck, but I struggle to input the 5.9 when the PCM and injectors don't know it is 5.9 engine. |
Use the actual engine size.
Using engine size, rpm, and MAP, the SG can calculate how much oxygen is being pumped through the engine. (piston pumps per minute * cylinder displacement * air density) Then, assuming it's fuel injected and uses closed-loop O2 sensor feedback, the fuel must be ~1/14.7 of the air volume for a clean burn. ------------------------ Really, though, calibration doesn't have to be ideal. If you improve your driving technique by 10%, you'll see a 10% improvement at the pump. ------------------------ |
Backtobasics -
It's too technical for me too. I've read versions of similar algorithms over and over. Everything I did is based on this post : Calculating MPG from VSS and MAF from OBD2 What I programmed is a lot of trial and error until I saw MPG behavior in the same range as the SG. CarloSW2 |
Backtobasics -
Code:
IMAP = RPM * MAP / IAT CarloSW2 |
Hey, one doubt here:
If MGuino MEASURES the injector pulses and integrates them, whereas SGII just 'guesses' about the fuel being used, I would expect MPGuino to be more accurate. Is this conclusion correct? Also, what is the strategy the in-built FE meters in the new generation cars use? SGII one, or straight computation of fuel a-la MPGuino from the ECU itself? |
