Show off your Grille Block
Made from truck bed liner:
http://ecomodder.com/forum/emgarage-...b6cf5e8dd2.jpg |
1 Attachment(s)
Made from the rear spoiler of a 90's Subaru Legacy wagon.
This is the second Insight I fabricated this same kind of grill block for. It looks so OEM it's almost invisible, and Insights without one look funny to me now. http://ecomodder.com/forum/attachmen...4&d=1446544207 |
Lots of people ar telling me that they cant really see the différence until they're up close.
http://ecomodder.com/forum/member-be...aps-blocks.jpg |
1 Attachment(s)
I saw this Kia Soul in a parking lot; I am pretty sure that is OEM:
http://ecomodder.com/forum/attachmen...1&d=1446573585 The lower grill was only made about half open; there were holes on the front, but flat plastic in the back. I noticed a few new cars like that. |
Svietlana's lower grille block:
http://ecomodder.com/forum/attachmen...9&d=1345062915 Openable (powered by 2x powerlock motors) - smaller for intercooler, larger for radiator. |
Older version :
http://i877.photobucket.com/albums/a...yb17/block.jpg Newer version. In winter, I block off the right side with a flat piece ( with matching teeth ) : http://i877.photobucket.com/albums/a...yb17/noway.jpg |
The testing showed some detached flow right at the hoodline. |
That being said, I'm afraid I'd be pushing my luck with completely blocking off the top for the radiator unless you're talking about the faux grill that rests right beneath the hood which serves no purpose whatsoever except for 'asthetics?' If that is the case I will definitely make one up this weekend and give it a shot. :thumbup: |
Afraid to block off too much?
Leave ~two inches on each side and that'll create sufficient Venturi to cool the RAD enough, especially going into the winter. Put slider(s) in there(looong pieces or the wind will take...!) and slide that to block on YOUR demand. |
VERY, wait!
Where is that thing..? Gorgeous is all I can say, "nice"...:thumbup: Quote:
More HAHAHAHA but nice job in and on your Honda. |
6 Attachment(s)
upper v.2
Attachment 19035 Attachment 19036 lower Attachment 19037 Attachment 19038 Attachment 19039 Attachment 19040 Average 0.3 L/100km gain on daily work commute. up to 0.5 gain on highway long distance trips |
If so, I would plug it, since from what I recall, this was causing some airflow disruption. |
I wasn't the first person to do spiral hubcaps on Ecomodder. Sven7 beat me to it, but I have had the idea for years. I was inspired by M.C. Escher and the old hippie vans that had these. Far out man |
Once it gets down around freezing i should be set. Only one tank thus far but i may gain as much as 10%! |
I dont have any experiencewith forced induction, but your engine will never go lean unless there are component failures. Your o2 sensors will keep the fuel mixture in the correct range. Those horror stories are from people building and tuning engines. I do know that there is some worry about the longevity of the turbocharger when engine off coasting, if there is not adequate time for it to cool down after a period of high usage. |
1 Attachment(s)
This is my upper grillblock. I.ve made it from 5mm scrap alluminum. I fits nicely and run it trough the heatwaves. Only in standing traffic the fan comes on to cool it down again and turning off. Only to slowly warm up over a 40 50 sseconds time.
http://ecomodder.com/forum/attachmen...7&d=1446979286 |
Brandon Mods,
How about trying spark plugs that are a couple of ranges cooler? That shoud reduce cylinder/piston temp some. |
1 Attachment(s)
Here is my grille block Attachment 19064 Didn't do any testing, but I haven't seen a difference yet, not even in warm-up times. :(
Hotter or cooler plug TIPS create hotter/faster spark or cooler/slower depending on combustion chamber design.
Example: 2 stroke or Wankel engines |
NGK Spark Plugs |
HAHAHAHA, you must be a "young one"...
BEFORE anything that resembled computers, spark(timing) was THE manner to adjust. Yes, distributors were what organized the electric discharge but final say-so was THE plug and ITS heat range... |
Some factory grill blocks:
http://i1047.photobucket.com/albums/...ps2yw8sldf.jpg http://i1047.photobucket.com/albums/...psv5wqbjbv.jpg |
Thanks Vman. My neighbor has one of those Kias, and i noticed the block.
Some models of that same vehicle have them, while others do not. ( I think his has an 'eco' emblem on the back ) I had never seen the MB grille block before. I thought perhaps it was a European version, but i see the Illinois plates. I'm reminded of a comment about ecomodding from another forum some years ago. It was something like " Stupid hypermilers ! If this #@!* really worked, automakers would have been doing it already. " |
Sorry to beat a dead horse, but only change plugs with the OE specified plugs. Don't "upgrade" them.
Edit: Just checked fueleconomy.gov--the regular Soul is rated 24/30/26, and the Soul Eco is rated 24/31/27. |
This listing on eBay shows the louvers quite well. Doesn't seem completely air tight in the closed mode though.
New Grille Grill 2015 Mercedes W205 C Class C300 Sedan w Air Panel Shutters | eBay |
Vman, was that Kia's lower grill completely blocked? The Soul that I saw was about half open.
It's open along the top and bottom, and inexplicably in the top corners. Are there brake cooling ducts or something on the Soul?
Not quite as purdy as others on this thread so far:
https://lh3.googleusercontent.com/-D...520Q1-2014.jpg |
Opel grille block
1 Attachment(s)
Hi,
Here is my Opel Astra grille block. It´s made 3mm thick black coroplast and I installed it with cable tie. Average fuel consumption drops about 0.1-0.2 liter /100km. http://ecomodder.com/forum/attachmen...3&d=1447585341 |
