Side View Mirror Downsize
Hello -
I am working on a side view mirror downsize. I got this bicycle handlebar mirror from REI : Blackburn Multi Mirror http://img519.imageshack.us/img519/3...or01jj6.th.jpg Here it is installed on my driver's side : Front View http://img509.imageshack.us/img509/3...or01ki4.th.jpg Here it is from inside. I have a round blind spot mirror on the inside too : Small Mirror http://img360.imageshack.us/img360/6...viewsl6.th.jpg Here you can see a tuft test with the normal passenger mirror. The two forward tufts are being "sucked into" the normal mirror : Normal Mirror Tuft Test http://img364.imageshack.us/img364/7...testik9.th.jpg With the small mirror, the lower forward tuft is lined up nicely. The upper forward tuft is pulled up, probably toward the front side window air deflectors. I need those to stop rain from getting into the car and to mitigate my "no AC" window crack. Small Mirror Tuft Test http://img360.imageshack.us/img360/2...testvo0.th.jpg I won't install a downsized passenger side view mirror until I can solve this problem on the installation : Mirror "triangular cover" Gap http://img355.imageshack.us/img355/3...rgapcm4.th.jpg This means rain can get into my door, :( . I could remove my passenger side view mirror altogether, but I am partial to symmetry (my bad, :o ). CarloSW2 |
Very nice. I especially enjoy the tuft test images.
Nice job, Carlos!
What is causing the gap, the fact that the bike mirror has to fit in somehow? |
heat gun and some silicon will take care of that gap..
SVOboy -
CarloSW2 |
Chris D. -
CarloSW2 |
Love it!!! I hate modern barn door mirrors. I liked the ones that mounted at the top of the A pillar.
Carlos Nice job. What are your driving impression with it? Also what are the deflectors for?
Lazarus -
In terms of impression, during the day it is fine. At night I am still getting used to it. But, here is my ace in the hole : 1970's style Convex Mirror from JC Whitney http://img182.imageshack.us/img182/8...rrorba7.th.jpg As you can see, I can see it all coming : ZERO Blind Spots http://img182.imageshack.us/img182/3...rrorci2.th.jpg The deflectors were already in place before I became an Ecomodder : When does having your windows down start to effect your mileage? Reply to Thread Quote:
CarloSW2 |
My truck still has vent windows. I have an extra set, I should drill them out and attach a small mirror to it.
