Silverado aerocap build thread
1 Attachment(s)
Nice work on the radiused side-top transition.
Added to the project library & looking forward to the progress. Any plans to A-B-A test the finished work? |
I'm not sure I've got my scangauge quite calibrated. I'll probably try to do some testing in a few weeks.
I'm very curious to see hard data. |
I like it too. Looks like a very sturdy rib cage and a good start.
Sweet!
I can already see the air slipping over it.I believe you'll be pleased at the pump.Nice fabrication!
Looks really good so far.
OSB - the rich man's cardboard.....:thumbup:
Looking forward to more. :thumbup: so far.
Dave |
1 Attachment(s)
Total investment: 4 2x4s = $7 2 OSB = $12 2 1/4" Ply = $17 Aluminum Tape = $11 Shrink Plastic = $15 Grand Total: $62 This is really just a test to make sure I can to it and work on perfecting the shape. If I can get the kinks worked out and if I see enough of an economy improvement then I'll go for something a little more permanent and better constructed. Update: Done for now. I've got a couple hundred miles to drive during the next couple of days so I'll report back on my experience. I might do some tuft testing to see if it is too high - I'm a little concerned about a couple of the edges. I'm also concerned about the gap. I may need to come up with some kind of filler. http://ecomodder.com/forum/attachmen...1&d=1262241744 |
