EcoModder.com
-   -   simple muffler question. (https://ecomodder.com/forum/showthread.php/simple-muffler-question-32263.html)
dirtydave 06-28-2015 06:56 PM
Well my muffler fell off (rust) and Midas replaced it last in 2010.
I'm almost positive I have a warranty but if not I was looking for one at a major chain autozone, advanced auto, pep boys, salvo, and napa.
I might need to buy one tomorrow.
How are they any different from each other??
the $45 one and the $90 one look the same.
whatmaycome14 06-28-2015 07:00 PM
I don't think that any choice would have a significant effect on mpgs...
maybe sound, but not fuel milage.
I'd go with the cheaper of them.
dirtydave 06-28-2015 08:04 PM
great thanks
dirtydave 06-28-2015 10:24 PM
would a $27 glass pack be a bad choice? looks like it would fit nice under a belly pan
http://m.advanceautoparts.com/mt/sho...983%7CL3*15335
Vman455 06-28-2015 10:33 PM
Ah, the Cherry Bomb--that takes me back to high school. It will be a lot louder--a lot louder--but that will work, sure. Those are a 2.5" inlet/outlet, bigger than the stock exhaust on both the cars listed in your garage, so you'll need to weld in an adapter before the muffler.
spacemanspif 06-28-2015 11:56 PM
Cheaper one will fall apart faster. I put 2 on my saturn. 1st was a steel replacement that rusted out in a couple years, second was the more expensive stainless steel replacement and held up better but still needed to be replaced if I had kept the car. Either way you look at it I needed to buy 2 mufflers for a car I drove for 110k miles and needed a 3rd. My experience is buy the cheap one and plan to replace it often because the expensive one is not going to last long enough to warrant the extra cost.
2009Toyotoad 06-29-2015 03:09 AM
That's a little surprising, but I guess it depends on the car. Mine did increase over stock. It was modest, but as the little 4 cylinder breaths a much better. The effects may bigger on a smaller engine. I went with TRD, which in my case was actually Borla exhaust.
ksa8907 06-29-2015 02:02 PM
A glasspack will work fine and wont be too loud if you are sure to install about 18-24 inches of pipe behind the unit. The reason "fart cans" are so loud is that they don't have enough pipe behind them to smooth the raspiness of the larger diameter. Think of a trumpet... it quickly transitions from a small diameter to a large diameter.
California98Civic 06-29-2015 02:50 PM
FWIW, this debate about MPG and muffler choice has come up often and repeatedly. I did a summation post, with the crowd-source editorial assistance of the forum (it as links to the best dscussions): http://ecomodder.com/forum/showthrea...tml#post289125
(Upshot is that most likely mufflers have little or no effect on MPG unless the whole exhaust system is tuned along with the muffler or pipe-diameter changes.)
james
dirtydave 06-29-2015 04:18 PM
this shouldn't have been posted in here should have been in off topic tech. (sorry)
Midas didn't stand by the warranty so I went and got a $30 thrush turbo and gave my brother $40 to replace a section of pipe put a tip on the end and new hangers.
http://i.imgur.com/RHLKuY9.jpg
http://i.imgur.com/8VdiAjx.jpg
