EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Smooth wheel covers - what size pizza pan? (https://ecomodder.com/forum/showthread.php/smooth-wheel-covers-what-size-pizza-pan-16368.html)
Daox 03-08-2011 07:47 PM
For those of you who have done the pizza pan smooth wheel cover mod, what size pizza pan did you use compared to your wheel size? I am looking to put them on the Prius, so I measured the wheel and it is a 15" wheel, but the steel lip is 16" diameter. Also, there is a question of the pizza pan size too. Is a 15" pan actually 15" in diameter, or is it made to fit a 15" pizza and have a lip that makes it larger?
fjasper 03-08-2011 08:43 PM
FWIW, the pizza pans I ordered were almost exactly the nominal size. 18" pan is about 17 15/16" in diameter, edge to edge. This is about 3/4" smaller than the diameter of the visible metal part of the 17" wheel.
Daox 03-09-2011 08:53 AM
That is quite helpful! I'll get 16" pans then.
BamZipPow 03-09-2011 10:22 AM
Why not just make them out of coroplast? :D
http://i164.photobucket.com/albums/u...0/IMG_7985.jpg
Lighter, cheaper, less prone to damage other vehicles if it comes off... ;)
Joenavy85 03-09-2011 10:30 AM
Bam, how did you attach the disc? is that the screw head i'm seeing there?
BamZipPow 03-09-2011 10:32 AM
I tried hot glue at first...didn't hold to my alloy rims. :(
Then I tried...Gorilla Glue. Worked just fine...until it comes time to pull them off. It takes a little to break the bond but you can work it off a little at a time. ;)
The hole you see is the tire valve... :D
I'm gonna run by the local Discount Tire and git some of their scrap tire weights and see if I can use the steel clip part after I melt the lead off and use those to keep the covers on with. ;)
Joenavy85 03-09-2011 10:34 AM
what did you use to cut the disc's?
BamZipPow 03-09-2011 10:58 AM
Being coroplast...a sharp Xacto knife. Carefully measured the rim and where the cover was gonna sit into. The diameter was slightly less than the Walmart pizza pan. I just held the pan down and cut into the first skin layer of the Coroplast. Pulled the pan off and then finished the cut. Used one of those Stanley shaver/planers to trim it down to size. To git the valve hole, I just pressed hard where the cap was and then drilled it out with a ½" drill bit. Primed it with plastic primer and then painted them with flat black paint.
My material of choice was those small political signs...I think they were 18" x 24". I have a ton of those from the last election. I could probably make 5 more sets. ;)
fjasper 03-09-2011 12:18 PM
You are correct. Dangit, now what am I going to do with these 18" pizza pans?
gone-ot 03-09-2011 12:35 PM
...anybody eat pizza?
