Snake oil or real deal? Phoenix Fuel Converter
Chip Foose is not known to be the kind of guy to throw his weight behind these questionable devices, but in looking at the site there is a distinct lack of science/facts about the operation of this thing...
Phoenix Fuel Converter [admin edit: Google it or go to fuelconverter dot com] Anyone heard about this thing? |
Test Data - Fuel Converter Quote:
There is a table showing a Mack dump truck with A-A-A-A-B-B-B-B testing (four days of each), supposedly improving 29%. I do not know if just the emissions are supposed to continue improving or the fuel economy as well, the Mack truck looks like it continues to improve overall, but the economy varies wildly before and after. If it worked that well, I do not know why they would stop testing. If nothing else, I would think the owner would ask "Can I purchase that off of you? I will report the numbers every day!" I really want more data points, but I think that explaining what catalyzes fuel is more important. |
So... it is a fuel preheater.
I don't see how a catalyst could do anything here as there is no reaction to catalyze before the fuel comes into contact with the air. I doubt any bonds in the hydrocarbon chains will get broken. They will be weakened a tiny bit though - but that is due to heating the fuel, not any catalyst. |
Eh, I'm not sold. But then again, I'm no expert either...
For between $700 and $1,000 that thing better boost my MPG to 70. That price tag is quite a big pill to swallow and cost recovery is quite a long time out...
Well...
That webpage has all the classic markings of a snake oil pitch. Lots of claims, light on details. It does have some testing data, but not for gasoline engines. Chip Foose is a smart guy with a great vision for designing cars. He's a very accomplished artist. However, he is not an engineer and not a chemist. I certainly wouldn't buy it because of his claims. I wouldn't mind some of his wheels though. On the other hand, the basis of how the device works appears feasible, unlike most snake oils. I wouldn't immediately throw it in the Unicorn Corral.... yet. |
they did post a link to their independent 3rd party "science" here:
https://www.dropbox.com/s/xllzswp0ue...41534.pdf?dl=0 I looked through the Intertek report. a couple of things stand out: 1.) Its unclear if the fuel that was run through the chromatographic tests was passed through the catalyst multiple times or just once as would happen in a real world application. This is not specifically called out in the test data. 2.) It is hard to determine which pass is the control and which one(s) are the test(s). I am assuming "Stock Sample" listed at the end of the report is supposed to be the control? 3.) The Research Octane Numbers and their Contributions to Total do not match up in any of the tests. They look to be off by +/- a point. If your catalyst modifies these C13 hydrocarbons, what hydrocarbon does it modify it to? None of the other C1-12 hydrocarbons increase in any of the tests versus what I assume is the control. |
There is good scientific basis to catalytic cracking of hydrocarbon chains. However, even the most advanced lab tests need on the order of 260 deg C to have a usable reaction rate. Heated coolant is only going to be around 100 deg C and below.
There is another form of fuel modification where the catalyst is introduced into the fuel stream. This has been done for decades. However, this would mean the system runs out of the active ingredient at some point. |
