Snow Aerodynamics? = PERFECT Aerodynamics?
1 Attachment(s)
DO you think this tahoe would benefit from one
it's pretty clear the Snow created its own Aerodynamics THIS SNOW perfectly built Aerodynamics allowed the snow to smoothly flow over the hood and windscreen while at 35-38mph did not even have to use the wipers(some very heavy wet flakes did hit it though) it even plugged up the radiator https://ecomodder.com/forum/attachme...1&d=1577427815 |
1 Attachment(s)
When the wind is from the right direction you can get a similar effect on a stationary car:
https://ecomodder.com/forum/attachme...1&d=1577440018 Apologies for the image being upside down but I could not get it the right way up. I even tried to edit the picture to put it upside down before I uploaded it thinking it would then get inverted again to be the right way up but that didn't work. So please either stand on your head or turn your display upside down. |
Nice grille block. :thumbup:
Self-correcting as the weather changes. |
Snerodynamics: Not a reliable indicator of what's optimal.
1 Attachment(s)
I think they can be pretty good sometimes.
It would be interesting to test snerodynamics in a wind tunnel.
Post #284 1917 Golden Submarine https://ecomodder.com/forum/showthre...-26678-29.html |
