EcoModder.com
-   Off-Topic Tech (https://ecomodder.com/forum/off-topic-tech.html)
-   -   "Solar paint prep" (https://ecomodder.com/forum/showthread.php/solar-paint-prep-38478.html)
California98Civic 07-13-2020 01:00 PM
"Solar paint prep"
...is an off topic tech term for allowing your car paint to rot.
http://driventoattraction.com/wp-con...2-1424x915.jpg
Put on a sticker and placed in the rear window of a road driven car, "solar paint prep" becomes a technology for amusing the good natured, confounding the skeptical, boring the boring, and inciting the irritable.
https://eliteautorepairtempe.com/wp-...izona-Sun1.jpg
freebeard 07-13-2020 10:42 PM
Patina: orange rust is good but brown rust is bad.
nemo 07-14-2020 07:01 AM
Solar Paint Prep in Progress
Pass with Care!
Solar Paint Prep in Progress.
California98Civic 07-14-2020 11:24 AM
1 Attachment(s)
https://ecomodder.com/forum/attachme...1&d=1594740245
cRiPpLe_rOoStEr 07-14-2020 03:42 PM
Paint fading is not so usual as it used to be, or at least not so noticeable as fewer cars are painted bright colors anymore.
freebeard 07-14-2020 04:10 PM
I'm amazed by the Paintless Dent Removal videos on Youtube. You can have massive dents in new cars and the paint just bends instead of flaking. Then with a massive light and cheap hand tools you can work the metal back to it's original contour.
I'm thinking about trying it on the dents from things falling on the Superbeetle in the carport. They glue slide hammer pucks in the dent and remove them with rubbing alcohol. I can do that with Gorilla Glue. I should have a slide hammer with my Unispot.
California98Civic 07-14-2020 09:35 PM
I have watched a ton of PDR videos, too, man. Thought about buying a kit. But nah. Dents intimidate the teslas, beemers, and Benzes in traffic and the parking lot. lol.
Piotrsko 07-15-2020 11:03 AM
The gorilla glue won't dissolve in alky. Use hot glue sticks which will, buck a bag at discount fabric shops, wallyworld, gun for application under $10.
California98Civic 07-15-2020 03:09 PM
1 Attachment(s)
Go for it, freebeard. I think the tech is impressive, too. Got any current photos of the car with its dents? This thread loves dents almost as much as stressed paint.
On another note ... I'm not saying I would do this exactly, but here was some interesting use of the divinely patented "longterm passive solar paint prep" process for an inimitable look. No kid with beer cans and piss could ever reporduce a patina panel with as much depth and character in its rot.
I like the contrast between highly stressed and perfectly new.
https://ecomodder.com/forum/attachme...1&d=1594840722
freebeard 07-15-2020 03:51 PM
Not gonna happen. When I spun out on black ice in 2016 I had to fight to keep a clean title. :( 2nd time was about a year ago, off-camber onramp after a Spring rain. It was the same left-side front corner. I'll admit I've had to conclude the tire combination on it has terminal oversteer on trailing throttle like a Porsche, it's bit me twice.
Tell you what though, I've got good used replacement fenders (right rear also) so when I strip and primer them I'll post pictures. Provided I've replaced the battery in my camcorder. Things move slow around here, especially up and down steps. :)
'On another note ...' I've got an early Beetle hood that is completely orange and brown metal. Except one little residual patch of thin paint. I should buff it and apply a wet sponge to finish it out. It cost me $5 at a swap meet.
Your example is literally Iconic:
https://www.youtube.com/watch?v=-vwcbTr8Oxc
From my albums:
https://ecomodder.com/forum/member-f...4-100-1049.jpg
https://ecomodder.com/forum/member-f...7-100-1040.jpg
https://ecomodder.com/forum/member-f...736-790095.jpg
https://ecomodder.com/forum/member-f...772994c062.jpg
Hmmm, there's sort of a theme that runs through them. :)
I've got a plastic model that has that same two-tone scheme in red on black. It's lifted directly from the Bugatti Royale. :thumbup:
