EcoModder.com
-   -   Some engineer types discuss ecomodding options for a 2004 quad cab Dodge 2500 pickup (https://ecomodder.com/forum/showthread.php/some-engineer-types-discuss-ecomodding-options-2004-quad-10903.html)
MetroMPG 11-07-2009 10:24 AM
Trading is not an option. I use this truck everyday and for what it is, it gets great gas milage. If there is room for improvement and an chance to learn something, then why not. I can do all the work myself. I am just looking for the best place to start.
Starts out as a question about gearing, progresses from there to the full gamut...
FYI:
Eng-Tips forum: Transmission, Driveline, Hybrid Drive engineering - Gearing for gas milage
The thread links to EM (to the Dodge pickup aero shell study), which is how I noticed it.
aerohead 11-07-2009 12:40 PM
discuss
They covered the bases pretty good! Some of the recommendations would require a re-design of the truck,but much could be mods as we know could be DIY.
Thanks Darin!
JQmile 11-07-2009 03:37 PM
Diesels are a great untapped resource for mileage gains. I just got 19.3 mpg on a 500 mile trip in my 89 Dodge, and it is running injectors that are 300 % larger than stock. Horsepower is 400 on fuel and 600 with nitrous. I am trying to get an overdrive in the works, as currently I am about 30% past the rpm for peak mileage. Keep in mind this is in a 5000 lb truck that is shaped like a brick.
Frank Lee 11-07-2009 06:06 PM
I've visited that forum over the years. There are some good pro engineers on there, and somewhat less of the usual nonsense. :thumbup:
ATaylorRacing 11-09-2009 12:56 AM
My oldest sons Hemi Ram Crew Cab 4x4 got a best of 21 mpg with him driving one way on a 240 mile trip....he was SHOCKED when I drove it back and got 23! It's the newer 09 that shuts down 1/2 the motor when cruising....he accelerates a bit harder and tends to stay at speed lomger when a stop is ahead.
Frank Lee 11-09-2009 01:21 AM
I have one helluva time busting 20 and that is with pretty careful driving.
Wish I could shut half my cylinders down at cruise... sometimes.
MetroMPG 11-09-2009 11:24 PM
Me too. I almost signed up once or twice to ask a serious question, but chickened out. I'm not worthy! :p
Frank Lee 11-09-2009 11:30 PM
No! You should go for it. You aren't going to pollute the place with nonsense, I know that.
