Some graphs of temperature vs. MPG
4 Attachment(s)
I started trip logs for my drive to and from school, and I'm bored right now, so I made some graphs of the data. I record the date, distance traveled, EOC miles on that trip, MPG for the trip, and the temperature. The distance, EOC, and MPG are measured by my MPGuino, and the temperature I look up at Welcome to Weather Underground : Weather Underground.
It's obvious that temperature makes a pretty big difference in MPG, but I thought I would make some graphs of it anyway, it's pretty interesting how the MPG follows the temperature: First, the MPG vs. Temp and EOC vs. Temp on a log scale axis for my trips to school: http://ecomodder.com/forum/attachmen...1&d=1237388832 You can see a pretty good correlation between MPG and temperature here, but it's better if I take the log of the temperature, and then graph it: http://ecomodder.com/forum/attachmen...1&d=1237388832 And the same thing for trips from school: http://ecomodder.com/forum/attachmen...1&d=1237388832 And with the log of the temperature... http://ecomodder.com/forum/attachmen...1&d=1237388832 The EOC figures can't really be directly related to the temperature, because my EOC practices are more determined by other people on the road. If there are people behind me on one of the roads I travel, I usually won't EOC as much, because there are no passing zones, and I feel bad making everyone else go 35 in a 55. I think it just worked out that on nicer days, there were fewer people behind me ;) It's only a small time frame, so the correlation isn't perfect, but I thought it was still interesting to see. |
The question is how much does engine warm up factor in?
Well, for all the trips going to school, I start the car, and spend about 1 minute clearing off the windows, as there's been frost on them every day. For the trips from school, I start the car, and leave, as the windows have been clear every day.
Next year, I'll try to get a block heater, and compare the results. I'm sure that they will be much higher, as engine warmup is probably the main factor for poor mileage in the cold. There's not much point in getting a block heater now though, as winter here is pretty much over. Once the engine is warmed up though, the coasting mileage is still worse at low temperatures than it is at high temperatures. Obviously, there are other factors, like wind, but on colder days, my mileage at 55MPH is definitely worse than it is on warmer days. |
Here is some of my collected data. Daily commutes for 2008 and 2009 so far. No AC in the summer.
http://mcguckin.us/files/car/mpg_temp_2009_03.png |
Cool, I was just about to ask for a plot of temperature versus mpg, rather than the two plotted against the date. The data are extremely noisy as I expected. McTimson, would you post a similar plot of your data?
Also, Pale, is that a polynomial fit? I would expect roughly linear behaviour, with discontinuities at the temps where you change your warm-up sequence, your ECU changes to a winter regime, and where you turn on your A/C.
Very cool data, guys!
I'll see if I can get a scatter plot in a little bit. I don't think it will look as nice though, I don't have nearly as many data points.
2 Attachment(s)
Alright, here's the MPG vs. temperature graph for my data:
http://ecomodder.com/forum/attachmen...1&d=1237424941 It's not as linear as I would expect, but I think that with more data points, it would become smoother. Again, this is only from like 2 weeks worth of recording, so it's not perfect, but it shows the obvious relationship between temperature and MPG. I also attached the excel file if anyone wants to play around with the graphs. |
There is a definite leveling off of any gains past about 80 degrees. I don't use AC, so that's not the reason. I'm guessing 80-90 is the optimum intake temperature for my car.
I have very little data at the cold end, as you can see, so that's somewhat suspect. Most of this winter's points were on the high end there, while last winter had the low points. I think early results skewed the data. That, or just unfamiliarity with winter driving for mileage. |
