Spark plugs
What does it indicate, if when you pull a plug, the threads are oily, and some oily sludge exists slightly outside of the compression ring, in a situation where the plug boot fully seals around the plug hole? (The plug hole was clean otherwise, so this didn't seep in from outside).
Who did the last plug removal before yours and why did they do it?
As sloppy mechanic doing a wet compression test? |
It was just a shot. Couldn't think of an obvious mechanical explanation, so I looked for human intervention. Could it have been a spec of crud under the compression ring preventing a 100% seal?
If the bottom (mating) surface of the ring is gummed up with sludge, it must not have had a good seal. If the ring is crushed, there must have been something trapped under the ring when it was seated. No?
Are you sure it's oil sludge and not some decomposed anti-seize compound?
These were my plugs. The problem? My thermostat was cooling in excess, making the mixture too rich.
http://i185.photobucket.com/albums/x...lasantigas.jpg http://i185.photobucket.com/albums/x...lasantigas.jpg |
