EcoModder.com
-   -   Spark plugs E3 Pulstar? (https://ecomodder.com/forum/showthread.php/spark-plugs-e3-pulstar-12741.html)
mazdamx640 03-25-2010 10:45 PM
Hi I have a 92 caprice that I am tryin to get 25mpgs while I still have a gas engine. I took a spark plug out today and it looks pretty fouled so I was thinking about getting E3s or pulstar plugs. Would they work or should I just get Ngks?
RandomFact314 03-25-2010 11:17 PM
I asked the same thing about a year ago and they told me they don't work but you could always test them out and let us know, I don't think it could get you WORSE mpg but who knows...
mazdamx640 03-25-2010 11:34 PM
At $25 a plug plus tax thats $214 for my car so I think I will wait till I see proof that they work. I'm not sure what the E3s cost but if its not too high I might get a set.
SVOboy 03-25-2010 11:56 PM
I wouldn't waste your time, just got with whatever the stock recommendation is, though you might consider indexing them :thumbup:
cfg83 03-26-2010 02:52 AM
mazdamx640 -
Here you go :
http://ecomodder.com/forum/showthrea...work-4020.html
Verdict: Bad news.
CarloSW2
Daox 03-26-2010 07:08 AM
Useless. They might show gains on a dyno, but it'll be small at that. One of my Pulstars also failed after about a year.
mazdamx640 03-26-2010 11:25 AM
What about the E3s there only about 5 or 6 bux each do they work?
tangomar 03-26-2010 03:20 PM
I had Halo and they gave me ~1.5mpg more consistently.
But I burned my coils (after a couple of years). Don't know if it was the sparks of just my car (it is 10 years old).
I just bought the E3 and I'll try them soon (pain in the @$$ to change plugs in my car).
Be careful in regards of the resistance. You should always put a plug that matches the coil inductance (I mean what the OEM specifies). If you change it too much you get extra current reflections at the spark and that pulse goes back to the coil.
Best thing to do is to mod your recommended spark plugs drilling a hole.
Domman56 03-27-2010 11:19 PM
E3's wouldn't be a bad idea
RandomFact314 03-28-2010 01:45 AM
According to the rest of this post, they are a crap idea...
Domman56 03-29-2010 02:09 AM
Well I've never heard anything bad about E3's from people who've used em but i heard the Pulsestars are really bad and unreliable
