Speedo outta calibration?
Hello!
Is there a way to calibrate the speedo? I believe mine is out. I have a GPS unit, and in the van, the GPS and Speedo read the same. But in the GEO, the GPS read 3-4kph SLOWER then the GPS... Speedo = 80kph GPS = 76/77kph I bought the car second hand, has 12" tires on it. would 13" tires correct the difference? Also, how is this affecting my MPG readings? |
It would be affecting your MPG readings if you don't have an SG or MPGuino, b/c the speedo controls the odometer.
If you want to correct it, you'll have to change tire sizes. The problem is that most vehicles come equipped with a "margin of error" on the gauges. If you notice that it's CONSTANTLY 3-4 MPH off, you can correct it by moving the needle. If it's a sweeping correction though (1mph at 20, 2mph at 30, 3mph at 40, etc.) You can only correct it by adjusting gearing and etc. |
Check the accuracy of the odometer. It is entirely possible that the speedo mechanism is off (internal springs or bearings) but it is keeping accurate track of miles traveled, in which case there isn't much for it except to try and clean the speedometer bearings and/or weaken the spring just the right amount (good luck :) )
Or is there an easier way to remove the window and adjust it? |
Is it just the speedo that is off or is the odo off too?
If one is off, the other would be too? |
not necessarily. Speedos are not historically super accurate, but odometers should be pretty accurate.
The whole assembly should be within 3% accuracy. I've got 12.5% low on my truck. I know it ain't the 14" wheels, that is the smallest rim they used.
You can usually pull the speedo out without removing the dash entirely. There is normally a bezel that you have to remove in front of/around the cluster.
The odometer is only ever off as a result of tire sizing, as it's gear driven from the speedo cable (or electronically driven from a VSS) the speedo is also driven by the cable, but it's driven by transfer of energy from the cable spinning a "fork" around a weight, and the weight is what's connected to the needle. I'm not really sure how to refer to the force at work there, but it's none-the-less pretty interesting when you see how it works. What actually happens is that the speedo cable's "fork" section spins furiously around a weight that is round, but they never make contact. The "fork" is basically whipping the air, and that causes the weight to move and hold against a very light spring. The fork produces just enough energy via tight tolerances and air friction to keep the weight in a specific area per MPH, which is displayed on the gauge. This is why mechanical speedo's default to 0 (or further). For VSS and electronic speedos, I believe it's just a signal input to an actuator which is calibrated as "pulse width input = length or distance output = speed display" IOW - the VSS signal tells the actuator how far to move, and the actuator is calibrated to move a certain distance to display each MPH. |
The only thing I can think of that could by some fluke be the cause is that we changed the speedometer cable to one from a scrap geo because the old one was sucking oil up the cable. Any ideas? Ben |
