SpeedTracer MPG graphing software and ...
SpeedTracer is a free clingon that is packaged with
AutoEnginuity software . i have had AutoEnginuity for years but never really tried the SpeedTracer until last friday. it works , the upper limit is set to 60 mpg and is not user adjustable , but the powers that be at AutoEnginuity have promised to increase the limit to 75 mpg for the next release . http://farm3.static.flickr.com/2652/...a9b30286_b.jpg the MPG graphing provides real time fuel economy in MPG MPG per the current trip current speed i have included 2 screen caps and a data-log graphed with open office |
All well and good but they want $50.00 for a upgrade...
Also to used it you have to fill out a TON of questions like tire size, gear ratio, engine size, weather conduction's like temp, air speed and direction, relative humidity etc...THEN it will work. I already get all that using my AutoXray 7000 OBDII Scanner, GPS, scangaugeII and other systems. Oh well |
So, if you get more than 60 mpg, it can't be used?
Sounds like a great fail. |
And again if your copy of Autoenginuity is less than a year old you can get a free upgrade... And after all how many people really do get over 60MPG?? Rich |
Ahh, I see. OK, I thought it was for MPG-nuts. Seems a bit anti-climatic if it was, ha!
Yeah, sadly, most of the rabbits on the road have no use for anything above 60mpg. Even though you can get a "buy and drive" option like a Prius, or a gas-free Leaf, they can't give up their gas suckers. |
