Squeezing extra MPG out of P&G (EOC WHILE KEEPING THE CAR ON??)
Ever since I took my car into the dealership to service, I disconnected my kill switch, so I have just been doing regular ENGINE ON P&G this whole week. I noticed something interesting.
This might not apply to all cars, but on my 2013 Subaru WRX Sti, I notice then when I shift to neutral to ENGINE ON coasting, my ScangaugeII indicates 9999mpg for a half second when rpms reach approx. 900rpm. Does this mean my injectors are actually turning off for that half second around 900rpm? I busted out my Torque App and drove to my regular “testing grounds” to verify. Testing grounds – 1 mile stretch of road with a slight incline, late at night, in a business park so no traffic to disturb I setup the Torque App to read FUEL USAGE to the 1000th decimal point, because I know fuel usage for 1 mile neutral coast would be minimal, but this is simply for testing purposes. I drove up to 40mph, shifted to neutral to initiate coasting , set the app to start reading fuel usage until a pre designated ending point. I did bi directional runs Straight engine on coasting .018 .015 .016 .015 AVERAGE - .016 fuel used Engine on coasting, blipping the throttle to allow rpms to sweep 1000rpms down to 900rpms .014 .014 .014 .014 AVERAGE - .014 fuel used Straight engine on coasting .015 .015 AVERAGE - .015 fuel used Total fuel used with STRAIGHT ENGINE ON COASTING IN NEUTRAL - .0156 Total fuel used with ENGINE ONE COASTING IN NEUTRAL WHILE BLIPPING THE THROTTLE – .014 That’s a potential extra 10.26% savings in fuel WHILE USING A FUEL SAVING TECHNIQUE! I’m thinking of the potential benefits for ecomodders 1) Achieve “simulated” EOC while keeping the engine on means you keep power steering on, you keep full braking power, you keep your ac running. 2) Less wear on clutch on transmission if you no longer need to bump start On this morning’s commute to work, there is a long downhill I normally coast in neutral, typically scangauge II reads 150-200mpg during the whole coast down, I blipped the throttle more rapidly to stay in the 900rpm sweet spot and my scangauge II indicated 9999mpg on the whole way down. I’ll do more testing and post up my Torque App readings later! |
It could be. But keep in mind that scangage & torque don't actually measure fuel consumption, they estimate it. They probably use mass air flow & O2 sensor.
That doesn't make sense. I think you've found one of the many places where the real world and the technological world aren't quite in the same plane. I suspect - and I'm going to subscribe to this thread because I really want to know more - that when you fill up it will turn out you've actually used more fuel.
If you haven't, well, I got nothin'. That would be me with a big heapin helpin of egg on my face. |
Was the car fully warmed up for the first A sets? I would suggest doing another B set after the second A to try to rule that out (so ABAB). Your sets are all extremely close, with your second A being right in the middle of the first A and your B. Looks too close to call it, in my mind, especially without being sure the instrumentation is inaccurate in this situation. |
I've still got my old mpguino , I'll hook it up and see.
I'll post my findings soon! |
my subaru does the same thing. I think it is actually using zero fuel for an instant as your foot comes off the gas it goes into open loop. which means it is disregarding the O2 sensor and fueling according to the fuel maps. at some rpm >~1000 and off the throttle it goes into DFCO.
am looking forward to confirmation or correction on this. |
I'm trying to find the floppy disk drive cable that came with my old mpguino, then i'll hook it up this week. I'll also grab my volt meter and hook it up to the injectors as well to see if the signal goes to 0 during that ~1000rpm range. |
Actually this might make a lot of sense. Perhaps its going into DFC for a bit. It could be more efficient to pulse the engine, blips, instead of just idling.
The potential is that i can get the same effect as EOC while keeping the engine on...thus less wear on clutch due to no more need to bump starting, you get to keep power steering on, you get to keep full braking power on, you get to keep air conditioning on, no need to hack wires to install a kill switch. My girlfriend approves this technique, she says "as long as you dont have to kill switch the car, its ok with me..." |
The wear from a bump start is pretty negligible given the forces involved. With a bump start you are getting the weight and drag of the moving parts of the engine going. Compared to just getting the car moving you are getting the whole mass of the vehicle moving. |
