steel vs alloy wheels
Is there a mpg gain to be had switching from steel to aluminum wheels? The ones I'm looking to get weigh about 8lbs lighter per wheel.
With no dollar consideration go w the weight reduction
there is a thread on here that experimented with the relationship between weight and mpg.
Long story short....for every 100 lbs you lose in weight, you gain 1 mpg. |
What about on hills? I drive 70 miles daily and I'm either going up or down. No level ground
The difference won't be measurable on a Ranger, but if you can get them cheap enough, I'd go alloy since acceleration and handling will also be slightly improved. I'd probably mount snow tires on the steelies and fuel efficient tires on the alloys so that they can be swapped easily as needed.
The longer you keep the vehicle, the more the investment in alloys pays off. Get the alloys used and you can sell them for what you paid for them when you go to sell the truck. |
When I swap between alloys and steel on my car I can't tell any differences. The tires are a bigger factor in ride and handling.
But the alloys will make the car look sexier. :cool: |
What other differences are there in the wheels and what tires will be on each? Width of tire and weight of tire counts. Diameter of wheel counts. Eight pounds per wheel can be multiplied by 2 or even 4, depending. That's because it is rotational mass. So your're looking possible at a 64-128 pound *effect* from lighter wheels. And as long as long as you don't cancel that out with heavier, wider, stickier tires, you could see a modest benefit. BUT... if you compou d the benefit by getting same weight or lighter tires, narrower, and of the low rolling reststance grade... even more benefit.... check tirerack.com extensively.
I'd be running the same tire I run now. Same tire in winter and summer. Sadly it's a commercial traction tire. It's aggressive but it's a hard compound and gets better mpg than snow tires but obviously not max mpg. For my uses I really can't switch wheels and tires as needed. I'm running MasterCraft courser ct 235/75r15
