EcoModder.com
-   -   Straightening CV axle(s) (https://ecomodder.com/forum/showthread.php/straightening-cv-axle-s-34242.html)
DragBean 08-27-2016 09:57 PM
Wondering how much if any of a fuel gain I'd get from having the CV axle(s) straight while driving?
They are currently only about 3 degrees (front to back from the car) of an angle.
I was considering moving the engine back 1" to eliminate this 3 degrees.
Or is this a waste of time?
Gasoline Fumes 08-28-2016 12:03 AM
I'd say it's a waste of time.
DaveM 08-28-2016 12:34 AM
Based on this paper, I'd agree, waste of time. I'd post a link, but do not have five posts. Google "cv joint angle efficiency NTN" It's the first hit.
They don't show joint efficiency below 3 degrees, I suspect because cv and u joints often require a bit of relative motion to distribute the grease and prevent wear in a single location.
LittleBlackDuck 08-28-2016 06:31 AM
There would be much higher gains from removing the grease and rubber boots from the joints as they contribute more to power losses.
Simon
me and my metro 08-28-2016 11:43 AM
Possible but it would cause problems with the inner ends. Just as a universal joint driveline you never want 0 degree angles. The joint will wear grooves in the cap and lock up. They need to move to live.
DragBean 08-28-2016 07:01 PM
Thanks for the input.
I'm thinking mine are probably more around 4-8 degrees...
3 degrees was kinda of a bad guess.
Anyways it seems like although moving the block an inch back would only take a half hour, it would basically be pointless.
I would say in terms of grease distribution I'd feel like the bumps in the road would be sufficient enough to distribute the grease.
DragBean 08-28-2016 07:07 PM
Wait a second, I was looking at the wrong graph
http://www.ntnglobal.com/en/products...n_064_067p.pdf
Based on Figure 9 moving the block 1 inch would probably reduce torque loss by .5 x2 (for both CVs) = 1%
Now mine are getting worn out, so I'd double that..
So now we're at 2%... almost 1 mpg...
LittleBlackDuck 08-28-2016 07:22 PM
Unless the roads you drive on are unbelievably rough, I would be willing to bet that centrifugal force and the action of the balls pushing grease out of their way will win out.
Seriously, I would be looking at harvesting all of the low hanging fruit before going to these lengths to get a miniscule gain that has the potential to damage parts.
Simon
DragBean 08-28-2016 08:59 PM
@littleblackduck
What about all the turns too?
LittleBlackDuck 08-28-2016 09:56 PM
Originally Posted by DragBean (Post 521608)
@littleblackduck
Way more drag from tyres. How often are you actually turning as a percentage of a trip? Anyhow, the total CV joint drag from turning is unlikely to be affected significantly by changing the static angles.
Another consideration is to ensure that there is sufficient plunge available so that you do not bottom out the joints during suspension travel and steering movement.
Simon
