Streamlined Citroen ZX
Good day, ecomodders!
Here is my latest project - Citroen ZX. http://imageshack.us/a/img43/2609/d0dp.jpg http://imageshack.us/a/img854/6787/9lqe.jpg This was actually the experimental part of my master thesis. I needed to analyse how drag affects a moving vehicle and how it's aerodynamics could be improved. So here is what I did. Firstly I created a rough model using Autocad. http://imageshack.us/a/img546/4031/gil3.jpg Then tested it with Autodesk CFD Project Falcon http://imageshack.us/a/img854/2346/woq7.jpg Then did the modifications and here is the final model http://imageshack.us/a/img545/5233/l6lo.jpg Put it in the CFD and got a Cd of 0.23 http://imageshack.us/a/img594/7736/h72h.jpg NOW here is the interesting experimental part. The build began from the underside. Policarbonate and sheet metal was used http://imageshack.us/a/img837/9991/s0u3.jpg Then the boat tail construction started http://imageshack.us/a/img856/8240/qjs9.jpg http://img198.imageshack.us/img198/1258/ut2f.jpg Boat tail underside made from textolite http://img844.imageshack.us/img844/3258/ysqq.png First test run early in the morning http://img811.imageshack.us/img811/4848/fm08.jpg Tuft testing https://scontent.xx.fbcdn.net/hphoto...92&oe=570568F7 Covered the rear wheel arches, partially blocked radiator ventilation and covered the fog lights + some final touches. And I give You the final result https://scontent.xx.fbcdn.net/hphoto...d2&oe=570D6665 https://fbcdn-sphotos-e-a.akamaihd.n...57862439_n.jpg https://fbcdn-sphotos-b-a.akamaihd.n...83768874_n.jpg http://img441.imageshack.us/img441/1669/0e6x.jpg https://scontent.xx.fbcdn.net/hphoto...53&oe=573C9B0C https://scontent.xx.fbcdn.net/hphoto...33&oe=570FA119 The summary The master thesis was graded as almost perfect. So first mission accomplished. Due to the lack of time and money the detail of this project could have been better. Currently I've removed all of the mods to adjust the brakes fix the clogged exhaust system and to make the car mechanically sound so to pass the mandatory checkup. The fuel consumption Orginal car ABA testing did 31.36mpg @ 56mph (speed limit). Modified car same road same speed but warmer weather did 49mpg. This mpg increase is very close to the one that was theoretically estimated. Yet currently Citroen without the mods is showing a significant increase in mpg compared with the old testing. This might be due to the exhaust system fix and the warmer weather we are having right now. Future plans Make the boat tail shorter and more practical. Connect to the ECU to take control of the fuel mixture. If you took the time to read this You are awesome.Feel free to like and share my FB page. http://www.facebook.com/flylowlt |
Warmer weather definitely improves mileage. My sig line has some numbers.
I started to put the car back together today. Since I have a bit more time now I can test more modifications individually. But before putting the flat bottom back on I've decided to see what difference in mpg would a front splitter make which I had laying in my garage from a rs fiesta.
http://img22.imageshack.us/img22/1247/17qh.jpg |
I forgot to add tuft testing of the final model in the first post. Unfortunately the camera focused on the windscreen when we were filming yet the tufts are still visible. The mods did a major difference in airflow.
Nice project! I like it! Do you think that you don;t have trouble because of a boat tail from the cops?
Hi,
wow you have done a lot of work on this car. If you want to modify it, I suggest you to make it narrower at the back. It will be better with side wind. |
You did a fantastic job not only with the car, but with your post here on EM.
All the information is nice and neat and you did all the testing that is usually done and showed your results. The final results look very much like a factory show car from the 1980s back when good aerodynamics actually brought bragging rights. http://www.powerful-cars.com/images/...obe-iii-14.jpg |
Great work and welcome to ecomodder :)
Copyright ©2000 - 2019, vBulletin Solutions Inc.
