"Stuck" clutch
The other day I did something stupid. 99.9% of my driving around here is on flat and level ground. The other day I was driving a route that I don't normal ly take and stopped at a stop sign at the top of a steep grade. Without thinking, I let out the clutch with it still in 3rd gear (dumb move!) It grumbled and rattled and let out a plume of black smoke, but then it seemed to take off okay. That is until I went to shift down for the next turn. I put in the clutch all the way and it clearly was still in gear. I pulled over and turned the truck off. At that point, I could shift just fine. I put it in 2nd, pushed the clutch in, and started it. It started really slow and was clearly still in gear even though the clutch was in. As soon as I took my foot off the brake it started moving. When moving, there was no way to shift--it wouldn't come out of gear. So I shut if off and tried starting in in different gears.
Eventually it started normally and has driven perfectly normal for several weeks now. It seems to me like the clutch was "stuck"--even though the pedel seemed to feel perfectly normal. And then for some reason, it came "unstuck" and has been fine since. What I'm wondering is, is there anything I should check to make sure everything's okay. The truck's got almost 100k on it, and this made me kinda nervous, but I'm not sure it's worth tearing into if it's acting fine now. |
I'd leave well enough alone. Something wasn't happy with the forces you put on it, but it sounds like the "range of motion" exercises you gave it managed to slap everything back into place.
is it the original clutch? was the engine hot when it happened? sounds like the clutch disc maybe froze in between the flywheel and pressure plate due to the extra torque. maybe from heat? i would go on the same hill again but this time pull out normally in 1st and see if it acts up again. if not i would keep driving it
slave cylinder may have been jared to a point were it stuck engaged, but once you pumped and shifted multiple times it worked loose?
my 95 firebird 3.4L T-5, clutch and slave cylinder needs to be replaced because of the same events... clutch had been replaced before but the slave cylinder is original(140k mi) debating on cable attached clutch this time around |
Then like fat Charlie said I'd keep on going. If it does it again under normal driving situations then it's time.
D.D. Sorry to hear about your trouble. Your Truck should have an inspection cover below the bell housing and in front of the trans ,pull the cover before the weather changes, a strong flashlight will help you see the damage! measure the clutch thickness . you may have just saved yourself a few $ and a tow job. The former owner more than likely started the problem and now you have found it. keep us posted
