A study on the effect of exhaust position on drag and lift
Impact of a vehicle exhaust pipe position on the lift and drag coefficients: 2D and 3D simulations
https://www.sciencedirect.com/scienc...40X?via%3Dihub Maybe i'm just tired or maybe something was lost in translation, but there seem to be contradictions in the text regarding lift and such..? I'll check again when fully awake, but thought it prudent to leave this here for everyone to read as, it seems my guess elsewhere here was right: There looks to be a worthwhile drag reduction to be had by placing the exhaust outlet in the middle of a car at speed's rear. Don't forget that hot exhaust has 4x the volume of cool intake air before whipping out your doubting calculator. :) I get 16 000 000 liters per minute for a 2L engine at 8000 rpm. Vacuuming out the exhausts is also going to help economy. Another link: https://www.wrcwings.tech/2022/03/22...rc-rally1-car/ |
It's not just you
https://ars.els-cdn.com/content/imag...00040X-gr3.jpg Where does the light green come from? Implicit biases: Quote:
edit: If you see an icon and line break at the beginning of the post, I didn't put them there. :confused: |
Both of my exhausts will exit optimally I hope thru my track cars "blown diffuser", in some ways I hope it is not too effective, as the throttle position will cause quick significant rear DF changes at times not always useful.
We'll see. |
I should redo this pic since I have better software. That said, the one in lower left has a Coanda nozzle:
https://ecomodder.com/forum/member-f...ed-stinger.png The Beetle has, by my calculation, 1500CFM of engine cooling air in addition to the [corrosive] exhaust. A 4 into 1 or 4 into 2 into 1 header with a 90 degree elbow would feed into a concave stainless steel box with an insert to make it annular. For drag, not anti-lift. |
Collecting the cooling lift then directing it, or just letting it flow naturally? Collecting it might require cool tin
' moving exhaust'
You would think more data is available from homebuilt aircraft: same style of engine cooling and exhaust system, but a cursory search indicates nothing very much new. Couple of radical installations that die after a while or rutans EZ has gone out of favor.
They all already have the car equivalent of very long, very aero boat tails, so there's not much vacuum behind them? The question I asked myself was:
Related to that would be the effect of:
Maybe also related:( The careful shaping and placing of the:
https://en.wikipedia.org/wiki/Meredith_effect I NB that The Meredith Effect requires the vehicle to be moving at much higher airspeeds than those of std autimobile travel, but the effect should still mitigate some of the cooling system drag of a vehicle. |
That may be so, but that 'vacuum' is pulling the car sideways (and cancelled by the same on the other side) not backwards... "After you figure out how to" not be an insulting ...rick, hell bent on eliciting bannable emotional reactions "check back with us"! The flow behind a car that's pulling it back and thus what I/we want to minimize is turbulent as hell. While the rotating wheels may have some effect, an explanation of what effect and how they might influence the position of max vacuum behind a/the car would actually be helpful vs whatever the above comment was supposed to achieve. As it stands; this comment is NOT at all helpful/educational and for all the world looks like an attempt to dissuade your following (god help them!) from even entertaining this idea for a moment! So then people might wonder: Is aerohead trying to help eco-modders/eco-modding? Or is he in fact trying to steer people away from light, effective, easily testable (with an old radiator S pipe) solutions..? And why..??? |
