Subaru Loyale - MPGuino Install
Howdy! I've been reading this forum for the last week, getting stoked on all kinds of mods. I just bought an MPGuino, it showed up in 2 days, I installed it tonight, and clearly I didn't pick the correct leads to tap into.
The unit displays just fine, but it isn't picking up VSS. I think I tapped into an unused VSS connector, but I just found on the Rostra site that I should tap into the YR coming from the speedo. Tomorrow... Perhaps a bigger problem is that, in the custom screen, it displays 6.5 GH at idle, and the number decreases as I add engine load. Neither of these terminals showed 12V with the ignition on and the engine stopped, as in the instructions, so I just tapped into the RW on this schematic. Will switching over to the other lead to the injector fix things, or is this a peak-and-hold problem? http://farm3.static.flickr.com/2637/...4000ca89_o.jpg My car is a '94 Loyale Wagon, 5spd, non-turbo, SPFI. Many Thanks, -Denny (Disclaimer - I'm a mechanical engineer, not a sparky. The vacuum gage went in tonight too, and works just fine :) ) |
Problem partially solved, I just found this post, and changing the Injector Trigger from 0 to 1 seems to have fixed the GH reading.
Tomorrow, I'll fix the VSS, and I'll make sure to update the wiki with calibration settings once I have them. Damn fine product, thanks to all the developers! |
Success! Still working on calibration settings. 9000 cts/mi seems about right for the VSS, no idea on the fuel setting.
Installed a vacuum gage and an injector kill switch while I was at it. Yeeha! http://farm3.static.flickr.com/2727/...116ce9b4e4.jpg |
Where did you tap into VSS and injector signals, what settings for fuel and vss signals. I just picked up an 88 SPFI Loyale (GL) and would like to install my guino into it.
I ended up abandoning the MPGuino because this car has a peak-and-hold injector, which isn't supported yet. Here is a thread about that. There is hope... if you want to build a signal conditioning circuit or rewrite the code.
http://ecomodder.com/forum/showthrea...or-6841-4.html I tapped directly into the injector wire at the plug near the throttle body. I can't say if it was on the + or - lead, because I couldn't distinguish colors on the wires there. For VSS I tapped into the yellow wire with the red stripe on the harness heading up to the instrument cluster. Check out page 155 of this PDF: http://jdfinley.com/downloads/Subaru...anualPart2.pdf |
Thanks
