success : pulse and coast in neutral at mid speed (40-55 mph)
I was using pulse and coast in neutral at low speed, ie in city, and dwl at higher speed (>40 mph). After last maintenance (oil from 10W40 mid-synthetic to 5W40 full synthetic; oil, air and gas filters) I felt more power at my butt-o-meter. I decided to try pulse and coast in neutral at mid speed (40-55 mph). I remarked I can now accelerate from 1100 rpm in 5th gear while before it was only over 1200 rpm.
I think we can say pulse and coast in neutral at 40-55 mph works :
So I beat best tank mpg and best tank distance twice in a raw :p I realized lately that my cost per 100km is lower than the one of a Prius II at EPA rating : 4.43 €/100km vs 4.89 €/100km ie -9% :) (here gasoline is 12.5% more expensive than diesel) but I generated 116.5 g/km of CO2 ie +12%. To be noted: previous best tank was in summer with front grill block and rear wheel skirts. These two tanks has been done without any aerodynamic help :cool: Denis. |
Congrats groar. P&G really is a great technique. :thumbup:
Groar, so you've taken you aeromods of? Why?
Removed the front grill block as I had a leak near the water pump and the engine was overheating. I do want to put some front grill block and rear wheel skirts back, build in coroplast, but it's too cold outside and day is too short by now... As the front is very flat, I think I'll try to make the front grill block convex to lower the high pressure zone in front of the grill. I'll also try a upper grill block, but currently I don't see how to fix it without fixing it at both hood and bumper. Denis. |
ooops, I did it again...
So I beat best tank mpg and best tank distance three times in a raw :p but I won't take the risk again to drive 100 km once the idiot light switched on, even if the tank theoretically contains 15.85 g. Quote:
About the Prius III, it has been announced at 89 g/km :thumbup: but I have to improve myself by 22% to achieve such a CO2 emission :eek: Quote:
Denis. |
My Mazda's manual says to run 10W-30, but I according to the Mazda dealer, 5W-20 and 0W-20 are more than satisfactory for lubricating the engine. The manual says 10W-30 because lighter weight oils were less readily available when my car was made. |
Denis. |
Groar,
Can you describe your pulse method a little? As in, how much throttle % are you giving? Do you vary the throttle by gear or by the RPM in a given gear? I ask because I'm trying to get a feel for how P&G has worked for different people. I tried 1 tank P&G in city, using 60-80% throttle, and my FE got way WORSE. I am currently trying it with about 40-50%, and this seems to be giving very marginal improvements. |
I use push and glide in speeds below 50 mph. Over that speeds I think the gain is so little that i dont bother to stress my engine and gearbox... On my diesel TDI I use flat out gaspedal method for acceleration...
With the two last tanks, driven with rear wheel skirts :
The skirts do help in coasting duration. On some small down slopes before I was loosing a little speed and now I gain a little speed. The skirts change the feeling of the car so much that I'm accelerating too fast and often drive over my max speed. While I was improving by 4%/tank without the skirts, I'm improving by 5.5%/tank with the skirts, ie a +33% improvement in the improvement :) Denis. |
