Synthetic Oil in my '81 cycle
So I got some Mobile 1 0w30 full synthetic oil for our trucks and was wondering if I can use the same stuff in my '81 honda cm400e. The manually suggests 10w30 as long as the ambient temperature is below 90 degrees F, it's air cooled. It's only that hot a couple days a year and I only ride it for short distances (10 miles between cooldowns) anyway, so I'm cool with that. The oil says it meets and exceeds all requirements for 10w30 so I should be good right? Does anyone on here have experience with this?
Another stupid question, I didn't see in the manual anywhere where it mentioned tranmission fluid. Is the transmission just cooled by the enging oil in the motor? |
Lots of bikes share the oil between the engine and transmission. In fact you have to be a little careful if you have a wet clutch, a buddy of mine put some fancy oil in his magna and the clutch started slipping.
As long as the oil does not say energy conserving on the ratings label it can be used. Energy conserving oil will not work well with the clutches.
To be safe i would make sure you get a motorcycle specific oil. They typically have different additives to help with the wet clutch, and the heat issue with air cooled bikes. I wouldn't use normal car oil. Amsoil makes motorcycle specific synthetic oil that is very good( i use it in my scooters) and i'm sure other companies make it as well. Just get an oil that says motorcycle 4-stroke synthetic and you will be good.
you will destroy your clutch unless you use an oil that is wet clutch compatible, I've changed a number of motorcycle clutches for this reason this mistake will cost you about $100 in parts and about 2 hours of your time.
I've had great luck with amsoil synthetic in my bikes, gained 1mph top speed in my honda cb100 when I switched (judged with a digital speedometer). |
Like coyote said, you don't want anything that says "energy conserving" or that has friction modifiers in it.
You don't have to pass your wallet through your nose for "special " motorcycle oil, which is probably plain oil without friction additives in it and the word "motorcycle" printed on the side. This guy uses Mobil 1 red cap and Rotella: Honda Motorcycle - Anyone using full synthetic oil in their Goldwing |
I have used mobil 1 20w50 non energy conserving synthetic in all my bikes always. Over 40k miles without ever having clutch problems :) If you have your manuals for the bike they all pretty much say the same thing. Use their brand or an equivalent non energy conserving 20w50 but they don't say you have to use a motorcycle specific oil since they are normally the same as regular oil just more expensive.
