EcoModder.com
-   -   taking a wai one step further (https://ecomodder.com/forum/showthread.php/taking-wai-one-step-further-21904.html)
SiVX 05-13-2012 12:29 PM
Pretty soon I'll be taking off my egr and intake Mani to do some cleaning and porting. I have an idea that I'd like to run by everyone. Since a warm air intake reduces pumping losses, could my system benefit if I painted the intake manifold with a paint that holds in heat? Basically ensuring that the air stays warm until it reaches the pistons. However this would also prevent the intake Mani from picking up heat from the engine bay, so I guess it could lower the air temp. I've never paid attention to this, but later I'll take the car for a drive and see if the intake side is warm to the touch afterwards.
t vago 05-13-2012 12:38 PM
It's a good idea.
I'm just not so sure you'd actually see any sort of gains at all.
amcpacer 05-13-2012 11:12 PM
Does your intake manifold have a hot coolant jacket?
SiVX 05-14-2012 04:18 PM
dont think so... its a 92 Civic VX. not alot of extra bits other than EGR and lean burn
