EcoModder.com
-   -   taller new tires? (https://ecomodder.com/forum/showthread.php/taller-new-tires-19588.html)
HydroJim 11-24-2011 08:15 PM
taller new tires?
I'm going to be getting new tires soon and was wondering if anyone had any input on getting taller tires. The stock size is 195/60R15, but the previous owner had 195/65R15 put on the car. The tread is almost gone so it's time to get new ones. I planned on the getting LRR tires but I'm wondering if I should go with the stock size or go to next size up which is currently on the car.
On the tires I'm looking at, its a difference of 27 revs per mile. I guess there is no reason not to go to taller tires, I'm just checking with the fuel economy experts on here.
My car is a 2000 Ford Focus ZX3.
oil pan 4 11-24-2011 08:27 PM
I went with 2 inch taller tires that were nearly 20 pounds heavier with my suburban and could detect no loss in fuel economy.
I say go big.
The skinnier smaller tire fad has not delivered.
F8L 11-25-2011 06:03 AM
As we allow know, the larger diameter tire will reduce rpm at cruising speed. Weight differ should be negligible. I would make sure you stay at the same width so you don't increase friction, get a LRR tire like the Ecopia EP100/Ep422, Energy Saver A/S, dB Super E-Spec or Nokian i3, etc. and ensure you register the speedometer difference so you don't mistake a mpg due to traveling slower/faster than you think you are. ;)
SentraSE-R 11-25-2011 10:35 AM
Tall tire test.
arcosine 11-26-2011 12:09 PM
Go with the taller tires for MPG, 205/75R15 or /70, 44 psi, if they clear suspension. For lower RR and snow use 185/65R15. Same OD as stock tire.
