EcoModder.com
-   DIY / How-to (https://ecomodder.com/forum/diy-how.html)
-   -   TDI NB Disabling Daytime Running Lights (https://ecomodder.com/forum/showthread.php/tdi-nb-disabling-daytime-running-lights-17348.html)
SwamiSalami 05-13-2011 12:47 PM
I found a great diy step-by-step online showing how to disable DRLs.
Here: Disabling Daily Runing Lights (DRL's) - How-To - NewBeetle.org Forums
I have but one critique. And, that is that the pictures of the connection are a bit misleading (or at least they were to me).
In an attempt to make it clearer which connection is to be disrupted, I have taken what I feel to be a better picture.
http://i29.photobucket.com/albums/c2...connection.jpg
Good for around a 1.5% mpg improvement!!!
good luck
euromodder 05-13-2011 02:12 PM
Holy smoke !
Ditching the DRLs was a 1.?? euro software mod on my Volvo ;)
SwamiSalami 05-13-2011 02:20 PM
According to research I've done this mod is good for around 1-1.5% improvement.
Here's the link: HowStuffWorks "How much extra gasoline would Americans use if daytime running lights were mandatory?"
Great article, too, btw.
UFO 05-13-2011 02:51 PM
Do you know how much current the DRLs draw? 1.5% sounds like a whole lot of improvement, yet very difficult to measure - 1% is less than half an mpg.
SwamiSalami 05-13-2011 03:10 PM
I sure don't. I know what you're saying, though. very hard to measure indeed. I'm not going to rack my brain trying to figure it out so specifically.
All that I know is that with my kammback attached I get 55.4mpg. if this improves mpgs by 1.5%, that theoretically should bump me up to 56!
SwamiSalami 05-13-2011 03:13 PM
p.s. UFO, you have a beetle! I'm telling you, this is worth your time. It took me 10 minutes.
Varn 05-13-2011 10:26 PM
At 49 mpg my jetta is burning 2.5oz of fuel a mile. Small things might make a difference. Be sure to drive without your AC and turn off your radio too.
guudasitgets 05-14-2011 08:01 AM
I'm surprized they still have them
SwamiSalami 05-14-2011 10:57 AM
they're mandatory in a lot of places.
Arragonis 05-14-2011 06:04 PM
I don't have DRLs on my (or Mrs A's TDIs) but we both run with headlights on (Xenons).
The result may be 1-2% MPG loss but to be honest a mistake on timing a light or timing a lane change or selecting when to shift up/down on a hill may make the same difference for or against FE on most journeys.
The positive result of lights on is that we have cut down the number of people pulling out without 'seeing' us by quite a bit. It is amazing how many do a double-take before deciding not to set off from a side road or change lanes.
So I'll stick with the lights.
