Temperature Effects
I was number crunching on my daily log data and thought folks might find this interesting. I plotted 80 days (160 commutes) worth of mileage and ambient temperature data:
http://ecomodder.com/forum/member-di...e3564-temp.png Mileage goes to the left axis, temperature to the right. Like everyone else, I can't wait for it to warm back up! |
Try cross plotting temperature against gas mileage. Temperature on the horizontal axis and gas mileage on the vertical axis.
http://ecomodder.com/forum/member-di...3565-temp2.png 40 deg F change results in about a 20% change in mileage. So mileage changes 1% for every 2 deg change. That's pretty significant. |
Awesome !
Nice this very good to see.
Nicely done. What were the dates of the 80-day period, and what is the date of the first and last frost for your locale? Any other relevant climate data by which to make comparisons? (or, do dawn/dusk considerations play a part?)
(For us the potential frost period is Nov 23 - Mar 9; with some as years [as this one] no frost at all; January thru first week of February constitute winter"; maybe only 10-days). A/C use is the bugabear for FE. You "commuters" can certainly have good data to work with in re set conditions of place and time over the year. . |
Now, *that's* the kind of number-crunching I like to 'see' -- show me the graphics (ha,ha)!
You've just documented & published the "Diesel Dave's TEMP Rule-of-Thumb": "... -1% FE change per each -2ºF temp change...and...+1% FE change per each +2ºF temp change." |
Dave,
how long is the comute? Does the vehicle start uotside (so the temp has settled in overnite) or is it in the garage? |
