Template Dimensions
Anybody have a x-y coordinate table for the Hucho template?
I am attempting to reduce it to sheet metal and need to generate a full-size pattern. |
Bolus Papoose
http://ecomodder.com/forum/member-fr...iler-show1.png Silver Streak http://ecomodder.com/forum/member-fr...iler-show0.png I owned one of those years ago. Here's a cutting pattern for a non-template boattail.http://ecomodder.com/forum/member-fr...lboxlayout.jpghttp://ecomodder.com/forum/member-fr...ticuda-tb5.jpg That's the best I can do painlessly. |
I have not seen xy coordinates on this site. But there are detailed notes in hyperlink #551 on this thread:
http://ecomodder.com/forum/showthrea...c-9287-19.html You do realize I assume that you will have to resize the numerical data to fit the max height of your vehicle. The Template measurements are made from the ground, not bottom of car or any other ref. This has been the technical position of the author of the template. |
Hey Dave, When I built my aerocap a few years back I made full sized drawings printed on large format printers at Kinkos and a local blueprint/drafting type shop. They were relatively cheap.
The drawings were based on MS Word Draw images which I converted to PDF files at 1/10th scale. When they printed them, they chose a 10X print size and Voila. The final product ended up within 1/8th inch over the largest part which was sure close enough for my world. Here's what I had printed. http://i44.tinypic.com/2rn7ul4.jpg Based on this side view. http://i41.tinypic.com/2zohq3m.jpg It looked like this. http://ecomodder.com/forum/member-ch...r-template.jpg *Note: These were made before I had learned about the template, so the final product was sloped too steep. It still worked OK. http://ecomodder.com/forum/member-ch...nished-cap.jpg Here is the last picture I took of it. http://i42.tinypic.com/2rcodwj.jpg (It was cluttering my garage up) |
I never had a precise measurement, but I noticed an uptick in my MPG by about 10% and the handling in the winter icy roads was remarkable, it really made the truck more stable at highway speeds. It just felt planted and wanted to go straight compared to the many "Grab the seat with my butt cheeks" moments I'd have without it on wintery roads. |
From my post #553 in Aero Streamlining Template part C:
http://ecomodder.com/forum/attachmen...p;d=1370031338 (Closer than the table I made in post 551) |
