Old 06-05-2013, 06:18 PM   #1 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Template Dimensions
Anybody have a x-y coordinate table for the Hucho template?
I am attempting to reduce it to sheet metal and need to generate a full-size pattern.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 06-06-2013, 02:29 AM   #2 (permalink)
Bolus Papoose
Silver Streak
I owned one of those years ago.
Here's a cutting pattern for a non-template boattail.
That's the best I can do painlessly.
aerohead (06-08-2013)
Old 06-06-2013, 12:33 PM   #3 (permalink)
OurInsight - '06 Honda Insight
I have not seen xy coordinates on this site. But there are detailed notes in hyperlink #551 on this thread:
http://ecomodder.com/forum/showthrea...c-9287-19.html
You do realize I assume that you will have to resize the numerical data to fit the max height of your vehicle. The Template measurements are made from the ground, not bottom of car or any other ref. This has been the technical position of the author of the template.
Old 06-06-2013, 02:24 PM   #4 (permalink)
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
Hey Dave, When I built my aerocap a few years back I made full sized drawings printed on large format printers at Kinkos and a local blueprint/drafting type shop. They were relatively cheap.
The drawings were based on MS Word Draw images which I converted to PDF files at 1/10th scale. When they printed them, they chose a 10X print size and Voila. The final product ended up within 1/8th inch over the largest part which was sure close enough for my world.
Here's what I had printed.
Based on this side view.
It looked like this.
*Note: These were made before I had learned about the template, so the final product was sloped too steep. It still worked OK.
Here is the last picture I took of it.
(It was cluttering my garage up)
The Following User Says Thank You to ChazInMT For This Useful Post:
Old 06-06-2013, 03:06 PM   #5 (permalink)
Top Gear would be proud.
Old 06-06-2013, 07:57 PM   #6 (permalink)
Did you gather any performance data
Old 06-06-2013, 08:24 PM   #7 (permalink)
Aero Deshi
ChazInMT's Avatar
Uh..It burned good....smoke was sorta greyish.
I never had a precise measurement, but I noticed an uptick in my MPG by about 10% and the handling in the winter icy roads was remarkable, it really made the truck more stable at highway speeds. It just felt planted and wanted to go straight compared to the many "Grab the seat with my butt cheeks" moments I'd have without it on wintery roads.
Old 06-06-2013, 09:51 PM   #8 (permalink)
betasniper's Avatar
Red - '01 Honda Insight CVT
Gen-1 Insights
House of Tudor
90 day: 59.17 mpg (US)
Civic Hybrid - '12 Honda Civic Hybrid
Bahamut - '18 Chevrolet Volt LT
Team Volt
Plug-in Hybrids
From my post #553 in Aero Streamlining Template part C:
(Closer than the table I made in post 551)
: Brothers
: Dad's
The Following User Says Thank You to betasniper For This Useful Post:
Old 06-06-2013, 11:10 PM   #9 (permalink)
Not Craigslist?
