Terminology for Engine off vs Engine on hypermiling techniques
Is there a good way to differentiate between Engine off and Engine on hypermiling techniques?
As I understand it EOC and P&G are typically engine off but don't need to be. I've seen some people use EO(n)C and EO(ff)C which is clearer but a little awkward. Haven't seen anything similar for P&G. Just trying to get a better idea of what techniques people are using so I know what works and what works better.:confused: |
Talk to six hypermilers, and you may hear half a dozen different descriptions of what they do. One will glide, another will coast. A third will say he does it NICE-on, the fourth does EOC.
My '02 SE-R didn't like the engine off, so I rarely shut it off. If I did, it would run in open loop for 4 miles, negating all the gains I made from shutting it off. It also hated to go into DFCO. I had to be over 2500 rpm to get DFCO, 65 mph or faster in 6th gear. It was a difficult car to hypermile. My '06 xB can coast engine off for miles, and still be in closed loop when I restart it. It loves DFCO, entering it when the engine is >1500 rpm, about 35 mph or faster in 5th gear. It's a breeze to hypermile it. |
PNG means pulse and glide with engine on
EOC means engine off coasting, usually with a bump start at the end of a coast. |
my understandin/vote is for.
EOC engine off coast neutral coast is engine on P&G pulse and engine off glide. PNG pulse and neutral glide (engine on). |
Apologies I probably started this (O)n vs (O)ff terminology mainly because I wasn't clear on the terms used - I think the explanations above probably clear it up.
I wanted to be clear on what I meant in my posts because I was looking at the effects of shutting off an engine with a turbo suddenly vs an engine which does not have one. |
PNG == P&G
and both are with the engine on amirite? |
no, p&g is engine off according to the glossary http://ecomodder.com/forum/showthrea...e-ii-3505.html and I think you just made up PNG :) |
I have created a monster, a monster....
I think unless someone specifically says Engine Off then assume they are on. Of course feel free to ask, everyone is nice here. :D |
Ok, tangent time. What's open loop vs closed loop and how would I know the difference while driving?
