EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Tested: hatch spoiler vs. vortex generators vs. stock hatch, 1996 Ford Aspire (https://ecomodder.com/forum/showthread.php/tested-hatch-spoiler-vs-vortex-generators-vs-stock-16573.html)
AeroModder 03-23-2011 06:44 PM
I finally got around to testing and recording the effects of VGs. The test used three setups (hatch spoiler, VGs, stock hatch) in an A-A-B-B-C-C format, using the same stretches of road. The tests were done with the least amount of time possible between trials.
With spoiler:
http://www.youtube.com/watch?v=pOZ37oopc18
http://www.youtube.com/watch?v=l1INZzGQIjY
With vortex generators:
http://www.youtube.com/watch?v=pB-BAYUJ2JU
http://www.youtube.com/watch?v=1-khQEH2Gcc
Stock hatch:
http://www.youtube.com/watch?v=JDA561vytLw
http://www.youtube.com/watch?v=Kka91kS6GmI
EDIT: Here's some photos of the mods:
Spoiler:
http://i3.photobucket.com/albums/y93...e/IMG_0231.jpg
http://i3.photobucket.com/albums/y93...e/IMG_0230.jpg
http://i3.photobucket.com/albums/y93...e/IMG_0233.jpg
Vortex generators:
http://i3.photobucket.com/albums/y93...e/IMG_0087.jpg
http://i3.photobucket.com/albums/y93...e/IMG_0086.jpg
The trip strips were in place for all three runs. After each run, the tested component was removed and all else left alone. The tufts proved the strips inneffective in preventing the air from wrapping around the pillar and producing vorticies.
Testing began at 10:30 AM with 20-25 minutes between runs.
Here's an older tuft test video showing the stock hatch:
http://www.youtube.com/watch?v=wm2RPqIE8HQ
Here's a video showing attached airflow from the vortex generators:
http://www.youtube.com/watch?v=gx084gKTLZ8
MetroMPG 03-23-2011 06:56 PM
Aeromodder - I'd suggest posting in a new thread.
Edit: moved.
Pendragon 03-23-2011 08:11 PM
I think you would have to make a longer run to come to a definitive conclusion, but it looks to me as though the spoiler just edges out the stock configuration and the vortex generators come in third.
The problem with VGs is that their size and placement is critical. They are not an easy fix, if at all.
Good video though, thanks for posting.
cfg83 03-23-2011 10:40 PM
Pendragon -
I agree. The devil is in the details.
CarloSW2
jakobnev 03-24-2011 10:33 AM
Could you add a description of each setup to this thread? (Pictures please!)
MetroMPG 03-24-2011 10:34 AM
Yes, please. Added as part of post 1 would be a good spot.
dennyt 03-24-2011 11:40 AM
I'd appreciate a results summary so I don't have to watch all those videos. Thanks for doing this test!
AeroModder 03-24-2011 11:43 AM
Updated with additional pictures and videos. As for results, I can't really tell a difference between any of the setups.
jakobnev 03-24-2011 12:09 PM
1 Attachment(s)
Interesting, would you consider testing a setup with the VG's slightly further forward and a spoiler(bigger than stock) at the bottom of the hatch?
http://ecomodder.com/forum/attachmen...1&d=1300983772
The idea is to keep the flow attached to the bottom and there recapture the kinetic energy of the vertical component of the airflow.
MetroMPG 03-24-2011 01:15 PM
Thanks for updating with pics.
Extend that spoiler into a proper Kammback, and you'll be able to detect an improvement. :)
