Testing Aerodynamics Through Software
I have found a way to test my Del Sol's aerodynamics and (if i can figure out 3D graphic design a bit) modify my car through software to test aerodynamics before actually modifying my car. I used Google SkechUp 8 to and through its "3D Wharehouse" I downloaded a 3D model of my car. Then you can download a 30 day free trial of a plugin called CADspan, which will allow you to export the file as a .STL file. After you have completed exporting the file you can open it in a wind tunnel simulation program called Project Falcon and look at your aerodynamics in many views.
If you have any experience with Google Sketchup or 3D graphic design, or maybe just want to give it a shot... You can modify your vehicle and test different designs with Project Falcon to come up with the best results for your vehicle. I know it seems like a lot of work (it isnt really) but I just thought it was really cool to see how the flow of air for my car and plan to test some different things (once i figure out Google Sketchup). Here are some pics of my car in Project Falcon http://img834.imageshack.us/img834/2...solaerotop.png http://img684.imageshack.us/img684/1...olaeroside.png In 3D http://img521.imageshack.us/img521/2427/delsol3dtop.png http://img99.imageshack.us/img99/4035/delsol3dside.png If anybody has graphics experience i would love a .stl with a kammback, grill block, and rear skirts on that thing :) |
How much does the software cost, and how hard is it to use ?
Thanks for posting ! |
Shortie771 -
This may be a big thing for us, because all of the wind tunnel simulators I have seen have cost bucko bucks. In the past we have documented 3D model locations on the web. When I go here : CADspan :: 3D Printing Solutions It *appears* that the plug-in is not the 30-day trial. When you use the plug-in during Sketchup sessions, does it say "X days left"? I also think that the wheels on the model are "solid", so I think you are emulating wheel covers right now. CarloSW2 |
Shortie771, what are the specs on your computer ?
( I have a 2.2ghz MacBookPro . Is it useless ? I'm willing to spend days on a render if that's what it takes, since I have been a 3D hobbyists since the late nineties and remember when it took that long to render a low-res 5 second preview .) |
That's really cool. I don't have experience in Sketchup, but do you need to "stitch" the model (make sure there are no holes) before using the 3D program?
The bottom two look very close to what the air "should" be doing. In other words, it follows the aero template. Follow those lines and you will have yourself a (theoretically) perfect boat tail. |
This is Autodesk software, and being the evil monopolize giant that they are, I suspected this to be a trial and sure enough, the software only works for a few days.
Does anyone know the cost ? I knew this was too good to be true. |
Sorry, I just realized that I had bot made "Project Falcon" into a hyperlink (fixed). I do not see anything mentioning Project Falcon as a free trial. Today will be my 3rd day using it, so when 7 days comes around I will let you know if it kicks me off.
