EcoModder.com
-   -   are there any practical things we can do with hot radiator water ? (https://ecomodder.com/forum/showthread.php/there-any-practical-things-we-can-do-hot-7144.html)
modmonster 02-16-2009 06:44 PM
its easy to divert the coolant hoses in a car -the veg oil diesel guys have taught us that.
what *practical* things can we do with hot water for energy saving?
Frank Lee 02-16-2009 06:46 PM
Put it in a thermos and release it again on next start-up.
modmonster 02-16-2009 06:49 PM
what about heating up lots of water with a heat exchanger and then using that water for heating your house?
Frank Lee 02-16-2009 06:51 PM
You think there is THAT much heated water?
modmonster 02-16-2009 06:56 PM
how could that be retro fitted to a car? could we re-route the coolant hoses to a big 10-20litre insulated tank in the trunk or passenger foot-well?
modmonster 02-16-2009 06:58 PM
obviously we would need to add more storage for the home heating idea
Frank Lee 02-16-2009 07:01 PM
That could be. I don't think 10-20 l will cut it. Imagine a 5 gal pail of boiling water in your house. I don't think there's an appreciable amount of heat there.
I reckon there's calcs to show how much energy is in, say, a 55 gallon drum of coolant at x temperature. Of course, that drum would have 459 lbs of coolant in it...
modmonster 02-16-2009 07:07 PM
actually i started this post because i was thinking about the steam engine idea but from a practical DIY perspective.
modmonster 02-16-2009 07:14 PM
the thermos flask for hot start up idea would work with a 20litre tank. from my biodiesel days, i know that a 20litre tank should keep its heat over-night if insulated. if its positioned in the passenger footwell the escaping heat would nicely warm the car. but would the weight be an issue?
modmonster 02-16-2009 07:31 PM
would it be practical to make a steam engine to replace the alternator using these components?
heat exchanger from ebay -boiler
drill pump from ebay -turbine
drill -alternator
your existing radiator -condenser
a solenoid valve -to do the reciprocating
