Think Flight: Using Simple Aerodynamics to Beat High Gas Prices
Published Aug 31st. Delete if a repost.
35.64mpg to 40.52mpg https://www.youtube.com/watch?v=O-FY...el=ThinkFlight |
I put it in "Interesting Aeordynamic..." but don't delete. It's just lost there.
What can one see from the thumbnail, that he took tuft testing to find out? |
what see
Also, from other reportings, the addition of rear wheel skirts and a full belly pan with diffuser would have amplified the 13.7% mpg result. So, anyone wishing to improve on the tail would select smaller angles on the sides and bottom, for the 'second-approximation' design. When the tufts behave as up top, you're essentially 'there.' Additionally, if the coefficient of pressure profile were to be determined, this would be 'what you're looking for', by default. |
Admitedly the plan taper doesn't show in the thumbnail.
Compare the Breer high-tailed stinger vs Harry Westergard's taildraggers. |
Westergard
They all look too aggressive to me. Pseudo-Jaray 'fastback'. I'd bet a cup a Joe and a sugar-dum-dum that they'd suffer premature separation.
'Like the look though.:) |
I didn't watch, but I don't think aviation is a simpler frame for aerodynamics. The entire subject is extremely complex, perhaps with a few easy to remember "rules of thumb".
As with any subject, the basics are low hanging fruit, with mastery involving lifetime dedication and proclivity. |
He's a pilot, it's a build story with tuft testing. |
Meh. Laminar flow better than turbulent? Is that what thinking about flight is supposed to reveal? I still refuse to watch based on the dumb title.
Perhaps we should use simple golf ball dimples to beat high gas prices? |
The aerodynamicist's tool?
https://www.matcotools.com/productas...yImage_400.jpg https://www.matcotools.com/productas...yImage_400.jpg |
Close but not quite. That would be for peening the edges of metal shafts to retain them.
You need a pick hammer to make proper dimples. |
