Old 07-21-2010, 07:16 AM   #1 (permalink)
weight loss $/lb on a truck calculation
I' watching max weight of my dads truck to make sure it doesn't go much over the payload capacity. However for economic reasons I wonder how many $/lb in a weight savings is worth? He drives 20K per year 3/4 highway. Alot of the stuff that I have to add to the truck for utility comes in either steel or aluminum.
Old 07-21-2010, 08:40 AM   #2 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Well, the amount of energy you'll spend hauling that around, excluding braking, is:
distance driven * CRR * 9.81m/sē * mass
divided by the efficiency at which you can produce power.
Then double it to account for braking. Then figure adding weight causes you to downshift and produce power less efficiently.
I figure you're looking at about 10gal/yr per 100lbs.
Old 07-21-2010, 11:17 AM   #3 (permalink)
Does that include the 5k year city driving?
Old 07-21-2010, 01:33 PM   #4 (permalink)
Left Lane Ecodriver
*shrug*
You're not going to get a very accurate answer without running it through a sophisticated computer model based on his particular driving style.
Tips needed for eco-driving my diesel truck! nubbzcummins Hypermiling / EcoDriver's Ed 65 12-07-2010 01:37 PM
Weight, where is the loss? brucey Hypermiling / EcoDriver's Ed 39 07-16-2010 06:53 PM
Big project-F250 pulling 20x8.5 enclosed trailer 5.0 Junkie Aerodynamics 70 04-11-2010 01:10 PM
Honda Begins Use of Class 8 Hybrid Truck Q1000 Hybrids 0 03-11-2009 07:55 PM
weight loss Memorytwo EcoModding Central 7 09-30-2008 05:17 PM
