Thoughts about CO2, CATs, & gasoline fuel economy
If burning one gallon of gasoline produces 20 pounds of CO2 (is that true?), and if a car with a properly functioning CAT is modded to get 60 MPG instead of 30 MPG, hasn't it halved its total CO2 output?
AND If gasoline catalytic converters produce CO2 from the CO and hydrocarbons in the exhaust, then isn't it possible that a 60 MPG car modded to run WITHOUT a CAT emits less CO2 than a 30 MPG car with a perfectly-operating CAT? (Obviously, emitting poisonous gasses such as CO is not a good alternative to emitting CO2, but I am curious what you all think.) |
The first conclusion is right though. Burn half the fuel, emit half the CO2. Again, that's basically true regardless of cat status. |
I don't think catalytic converters effect car fuel economy at all or barely at all.
After driving my electric so much I think fuel burners all stink. If you want to reduce back pressure removing the muffler and running just a converter would be better. |
That said, my hunch is that the difference is negligible, and it would be better to produce CO2 than CO, even if it's a stronger greenhouse gas. The main byproduct of combustion is water, though. |
CO is oxidized in the atmosphere, so the CO from a car's tailpipe eventually still becomes CO2. It just takes longer. |
CO will become CO2 in time and when it does it will make O3.
O3 has a short halflife in the order of hours to a couple of days depending on conditions.
It either oxidises something or decomposes in to O2. O3 is classified as a secondary pollutant. |
you can get good aftermarket highly rated 3 way converts pretty cheaply (get a California CARB rated 3way converter, don't get a 49state one as those are poorly made) (1.6liter) 82444 walker cat would upgrade you to 2001-2005 standard |
